boot mode 每个模式都测试过 J-Link: Flash download: Bank 0 @ 0x18000000: 1 range affected (131072 bytes)
Thu May 13, 2021 11:03:20: IAR Embedded Workbench 8.30.1 (C:Program Files (x86)IAR SystemsEmbedded Workbench 8.1armbinarmproc.dll) Thu May 13, 2021 11:03:20: Loaded macro file: C:Program Files (x86)IAR SystemsEmbedded Workbench 8.1armconfigdebuggerAnalogDevicesCM40z.dmac Thu May 13, 2021 11:03:20: JLINK command: ProjectFile = G:WorkDTUDTUSoftWareDTUsettingsDTU_Debug.jlink, return = 0 Thu May 13, 2021 11:03:20: JLINK command: scriptfile = C:Program Files (x86)IAR SystemsEmbedded Workbench 8.1armconfigdebuggerAnalogDevicesCM40z.JLinkScript, return = 0 Thu May 13, 2021 11:03:20: Device "CM40Z_384_2048" selected. Thu May 13, 2021 11:03:20: DLL version: V6.95d, compiled Feb 12 2021 16:38:31 Thu May 13, 2021 11:03:20: Firmware: J-Link V9 compiled Feb 2 2021 16:34:10 Thu May 13, 2021 11:03:20: JTAG speed is initially set to: 1000 kHz Thu May 13, 2021 11:03:20: ConfigTargetSettings() start Thu May 13, 2021 11:03:20: ConfigTargetSettings() Thu May 13, 2021 11:03:20: ConfigTargetSettings() end Thu May 13, 2021 11:03:20: InitTarget() start Thu May 13, 2021 11:03:20: InitTarget() Thu May 13, 2021 11:03:20: TotalIRLen = 5, IRPrint = 0x01 Thu May 13, 2021 11:03:20: TotalIRLen = 5, IRPrint = 0x01 Thu May 13, 2021 11:03:20: JTAG chain detection found 1 devices: Thu May 13, 2021 11:03:20: #0 Id: 0x228050CB, IRLen: 05, ADI TAPC Thu May 13, 2021 11:03:20: CM408x (InitTarget): Sending security key needed for CPU core access Thu May 13, 2021 11:03:20: Enabling core access Thu May 13, 2021 11:03:20: InitTarget() end Thu May 13, 2021 11:03:20: TotalIRLen = 9, IRPrint = 0x0011 Thu May 13, 2021 11:03:20: JTAG chain detection found 2 devices: Thu May 13, 2021 11:03:20: #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP Thu May 13, 2021 11:03:20: #1 Id: 0x228050CB, IRLen: 05, ADI TAPC Thu May 13, 2021 11:03:20: DPv0 detected Thu May 13, 2021 11:03:20: Scanning AP map to find all available APs Thu May 13, 2021 11:03:20: AP[1]: Stopped AP scan as end of AP map has been reached Thu May 13, 2021 11:03:20: AP[0]: AHB-AP (IDR: 0x24770011) Thu May 13, 2021 11:03:20: Iterating through AP map to find AHB-AP to use Thu May 13, 2021 11:03:20: AP[0]: Core found Thu May 13, 2021 11:03:20: AP[0]: AHB-AP ROM base: 0xE00FF000 Thu May 13, 2021 11:03:20: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) Thu May 13, 2021 11:03:20: Found Cortex-M4 r0p1, Little endian. Thu May 13, 2021 11:03:20: FPUnit: 6 code (BP) slots and 2 literal slots Thu May 13, 2021 11:03:20: CoreSight components: Thu May 13, 2021 11:03:20: ROMTbl[0] @ E00FF000 Thu May 13, 2021 11:03:20: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 Thu May 13, 2021 11:03:20: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT Thu May 13, 2021 11:03:20: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB Thu May 13, 2021 11:03:20: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM Thu May 13, 2021 11:03:20: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 004BB912 TPIU Thu May 13, 2021 11:03:20: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM Thu May 13, 2021 11:03:20: ROMTbl[0][6]: E0042000, CID: B105900D, PID: 002BB914 SWO Thu May 13, 2021 11:03:20: ROMTbl[0][7]: E0043000, CID: B105900D, PID: 001BB908 CSTF Thu May 13, 2021 11:03:20: ROMTbl[0][8]: E0044000, CID: B105900D, PID: 001BB961 TMC Thu May 13, 2021 11:03:20: ROMTbl[0][9]: E0045000, CID: B105900D, PID: 003BB906 CTI Thu May 13, 2021 11:03:20: ROMTbl[0][10]: E0046000, CID: B105900D, PID: 003BB906 CTI Thu May 13, 2021 11:03:20: ROMTbl[0][11]: E0047000, CID: B105900D, PID: 003BB906 CTI Thu May 13, 2021 11:03:20: ResetTarget() start Thu May 13, 2021 11:03:20: ResetTarget() Thu May 13, 2021 11:03:20: Reset handler: 0x18018268 Thu May 13, 2021 11:03:20: ResetTarget() end Thu May 13, 2021 11:03:20: Warning: Error while evaluating J-Link script file: Error while compiling. Line 199, column 3: Thu May 13, 2021 11:03:20: __int64 BaseAddr; Thu May 13, 2021 11:03:20: ^ Thu May 13, 2021 11:03:20: Syntax error Thu May 13, 2021 11:03:20: Failed prepare script file Thu May 13, 2021 11:03:20: Hardware reset with strategy 3 was performed Thu May 13, 2021 11:03:20: Initial reset was performed Thu May 13, 2021 11:03:20: Found 2 JTAG devices, Total IRLen = 9: Thu May 13, 2021 11:03:20: #0 Id: 0x4BA00477, IRLen: 4, IRPrint: 0x1 CoreSight JTAG-DP Thu May 13, 2021 11:03:20: #1 Id: 0x228050CB, IRLen: 5, IRPrint: 0x1 ADI TAPC Thu May 13, 2021 11:03:23: J-Link: Flash download: Bank 0 @ 0x18000000: 1 range affected (131072 bytes) Thu May 13, 2021 11:03:23: J-Link: Flash download: Total: 2.080s (Prepare: 0.104s, Compare: 0.143s, Erase: 0.772s, Program Verify: 1.055s, Restore: 0.004s) Thu May 13, 2021 11:03:23: J-Link: Flash download: Program Verify speed: 121 KB/s Thu May 13, 2021 11:03:23: 110683 bytes downloaded and verified (46.73 Kbytes/sec) Thu May 13, 2021 11:03:23: Loaded debugee: G:WorkDTUDTUSoftWareDTUDebugExeDTU.out Thu May 13, 2021 11:03:23: ResetTarget() start Thu May 13, 2021 11:03:23: ResetTarget() Thu May 13, 2021 11:03:23: Reset handler: 0x180180BC Thu May 13, 2021 11:03:23: ResetTarget() end Thu May 13, 2021 11:03:23: Software reset was performed Thu May 13, 2021 11:03:23: Target reset Thu May 13, 2021 11:03:41: IAR Embedded Workbench 8.30.1 (C:Program Files (x86)IAR SystemsEmbedded Workbench 8.1armbinarmproc.dll) |
根据提供的信息,无法确定确切的问题。然而,可能由以下几个原因导致无法将程序下载到ADSP-CM408F的Flash中:
1. 引导模式设置不正确:确保正确选择了正确的引导模式,以便将程序下载到Flash中。根据提供的信息,您似乎已经尝试了所有的引导模式,但仍然无法下载。 2. 调试器设置问题:确保使用的调试器配置正确,并且与目标设备兼容。确认使用的是适用于ADSP-CM408F的正确设备描述文件。 3. Flash擦除问题:使用J-Link命令下载程序时,默认情况下会擦除Flash中的程序。可能需要确认Flash是否已经正确擦除。 4. 驱动程序问题:确保您使用的是最新版本的J-Link驱动程序,并且与使用的IAR Embedded Workbench版本兼容。尝试更新J-Link驱动程序,然后再次尝试下载。 |
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
122 浏览 0 评论
565 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
772 浏览 0 评论
948 浏览 2 评论
《DNESP32S3使用指南-IDF版_V1.6》第二十六章 INFRARED_RECEPTION实验
658 浏览 0 评论
12041 浏览 31 评论
GMT+8, 2024-12-26 16:10 , Processed in 0.725767 second(s), Total 75, Slave 58 queries .
