FP32转换正常,FP16转换报错(model_transform正常)
运行命令为: model_deploy.py --mlir omniSR-DIV4x-simplify.mlir --quantize F16 --chip bm1684x --model omniSR-DIV4x-simplify.bmodel 报错信息: [ERR] /workspace/nntoolchain/TPU1686/firmware_core/src/local_layer/nodechip_group_norm_local.c:1072: nodechip_layer_norm_local: Assertion "0 < axis axis < 5" failed. Obtained 10 stack frames. /workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684x.so(+0x3194f3) [0x7fafc50964f3] /workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684x.so(__print_trace+0xe) [0x7fafc5096579] /workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684x.so(nodechip_layer_norm_local+0x8d) [0x7fafc4f92248] /workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684x.so(api_layer_norm_local+0x1e3) [0x7fafc4f691d9] /workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/lib/libbackend_1684x.so(backend_api_layer_norm_local+0xe0) [0x7fafc4e065b0] tpuc-opt(+0x4cb959) [0x5631b7ccb959] tpuc-opt(+0x402c30) [0x5631b7c02c30] tpuc-opt(+0x6f76ca) [0x5631b7ef76ca] tpuc-opt(+0x5b305c) [0x5631b7db305c] tpuc-opt(+0x5b37ab) [0x5631b7db37ab] Traceback (most recent call last): File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/tools/model_deploy.py", line 288, in tool.build_model() File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/tools/model_deploy.py", line 202, in build_model self.op_divide File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/utils/mlir_shell.py", line 154, in mlir_to_model _os_system(cmd) File "/workspace/tpu-mlir_v1.2.8-g32d7b3ec-20230802/python/utils/mlir_shell.py", line 50, in _os_system raise RuntimeError("[!Error]: {}".format(cmd_str)) RuntimeError: [!Error]: tpuc-opt omniSR-DIV4x-simplify_bm1684x_f16_final.mlir --codegen="model_file=omniSR-DIV4x-simplify.bmodel" -o /dev/null |
该错误可能是由于在转换过程中发生了某种错误导致的。具体原因可能有多种可能性,例如模型结构不兼容、输入数据类型不匹配等。
为了解决这个问题,可以尝试以下方法: 1. 检查模型结构:确保模型结构与目标设备兼容,例如检查是否使用了目标设备不支持的操作或层。 2. 检查输入数据类型:确保输入数据类型与目标设备的要求匹配,例如检查是否使用了浮点型数据而目标设备需要整型数据。 3. 检查是否缺少依赖:如果使用的转换工具依赖于其他软件或库,检查是否缺少相关依赖项,并确保它们已正确安装和配置。 4. 查看报错信息中提到的源代码行:如果报错信息提到了特定源代码行,可以查看该行代码来了解具体发生了什么错误,并在此基础上做进一步的排查和调试。 如果以上方法都不能解决问题,建议查阅相关文档或咨询转换工具的威廉希尔官方网站 支持来获取更详细的帮助。 |
H264硬编码CVI_VENC_StartRecvFrame报错的原因?怎么解决?
641浏览 2评论
使用bm-smi查看信息时发现没有程序运行但是设备内存被占用是怎么回事?
375浏览 1评论
392浏览 1评论
SE5盒子如何修改IP?执行bm_set_ip提示没有该命令?
390浏览 1评论
809浏览 1评论
GMT+8, 2025-3-7 08:58 , Processed in 0.532398 second(s), Total 80, Slave 63 queries .
