按照官方给的VisionFive2的EDK2烧录文档把SPL和JH7110.fd烧到QSPI flash,SPL烧录成功,但是JH7110.fd烧录失败,日志如下:
StarFive # StarFive # tftpboot 0xa0000000 192.168.3.151:u-boot-spl.bin.normal.out Using ethernet@16030000 device TFTP from server 192.168.3.151; our IP address is 192.168.3.200 Filename ‘u-boot-spl.bin.normal.out’. Load address: 0xa0000000 Loading: 7 MiB/s done Bytes transferred = 132240 (20490 hex) StarFive # StarFive # sf update 0xa0000000 0x0 132240 device 0 offset 0x0, size 0x132240 1159168 bytes written, 94784 bytes skipped in 7.30s, speed 182548 B/s StarFive # StarFive # tftpboot 0xa0000000 192.168.3.151:JH7110.fd Using ethernet@16030000 device TFTP from server 192.168.3.151; our IP address is 192.168.3.200 Filename ‘JH7110.fd’. Load address: 0xa0000000 7.6 MiB/s done Bytes transferred = 8716288 (850000 hex) StarFive # StarFive # sf update 0xa0000000 0x100000 8716288 Size exceeds partition or device limit sf - SPI flash sub-system Usage: sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus and chip select sf read addr offset|partition len - read len' bytes starting at offset’ or from start of mtd partition'to memory at addr’ sf write addr offset|partition len - write len' bytes from memory at addr’ to flash at offset' or to start of mtd partition’ sf erase offset|partition [+]len - erase len' bytes from offset’ or from start of mtd partition' +len’ round up len' to block size sf update addr offset|partition len - erase and write len’ bytes from memory at addr' to flash at offset’ or to start of mtd `partition’ sf protect lock/unlock sector len - protect/unprotect ‘len’ bytes starting at address ‘sector’ StarFive # 请问这是为什么呢?烧录的文件也是官方下载的,文件大小也是正确的。 |
VisionFive2中openplc页面无法打开怎么解决?
1099 浏览 1 评论
第一次启动StarFive VisionFive 2, U-Boot总是报错,为什么?
992 浏览 1 评论
VisionFive 2 生态进展双周报(1.1-1.31)
2124 浏览 0 评论
JH-7110现已支持AMP双系统(Linux + RT-Thread)
1527 浏览 0 评论
VisionFive 2 生态进展双周报(9.29-10.16)
876 浏览 0 评论
468浏览 2评论
455浏览 2评论
524浏览 2评论
324浏览 2评论
317浏览 2评论
GMT+8, 2025-3-30 17:48 , Processed in 0.318102 second(s), Total 42, Slave 37 queries .
