我想测试一下芯片时钟的精确性,需要将系统时钟输出,请问GD32VF103的时钟是通过哪个引脚输出的?以下是配置输出时钟为系统时钟,但不知道这个时钟是通过MCU的哪个引脚输出的?
GD32VF103芯片的时钟输出通过PA8引脚输出。以下是配置输出系统时钟的代码示例:
```c /* Enable AFIO and GPIOA clock */ rcu_periph_clock_enable(RCU_AF); rcu_periph_clock_enable(RCU_GPIOA); /* Configure PA8 as alternate function */ gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_8); /* Select timer15 PWM output as alternate function */ gpio_pin_remap_config(GPIO_SWJ_DISABLE_REMAP, ENABLE); /* Enable TIMER15 clock */ rcu_periph_clock_enable(RCU_TIMER15); /* Configure TIMER15 channel 0 as PWM output */ timer_oc_parameter_struct timer_ocinitpara; timer_ocinitpara.oc_output_state = TIMER_OC_OUTPUT_IDLE_STATE; timer_ocinitpara.oc_mode = TIMER_OC_MODE_PWM2; timer_ocinitpara.oc_polarity = TIMER_OC_POLARITY_HIGH; timer_ocinitpara.oc_idle_state = TIMER_OC_IDLE_STATE_LOW; timer_output_oc_config(TIMER15, TIMER_CH_0, &timer_ocinitpara); /* Enable TIMER15 */ timer_enable(TIMER15); /* Enable system clock output */ rcu_cfg0 &= ~RCU_CFG0_I2SCKSEL; rcu_cfg0 |= RCU_CFG0_I2SCKEN; RCU_CFG0 = rcu_cfg0; ``` 请注意,该代码配置了PA8引脚为TIM15_CH0的PWM输出功能,并将系统时钟输出到该引脚。你可以通过测量PA8引脚的频率来测试芯片时钟的精确性。 |
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
441 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
592 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
632 浏览 1 评论
GMT+8, 2025-2-23 07:40 , Processed in 0.497742 second(s), Total 44, Slave 39 queries .
