目前一个项目采用了24bit的AD7175-2,在正常采样信号是会经常出现变成0值,状态寄存器的第六位置位,指示超量程或者欠量程错误,而且出现错误时除非把AD再次初始化否则不能正常采样。请教大家这个是什么原因?只用AD0通道采样,非差分。采样信号来自三节1.5V电池分压。
下面是AD7175的寄存器初始化配置: {0x00,0x00,1},//现状_登记 {0x01, 0x800, 2}, // ADC_ mode_ 注册 {0x02, 0x01000, 2}, // Interface_ Mode_ Register {0x04, 0x0000, 3}, // 数据_ 注册 {0x05,0x0000,2},//IOCon_登记 {0x07,0x0000,2},//ID_st_reg {0x10, 0x8016, 2}, //CH_Map_1 REF-作为AIN- {0x11,0x0000,2},//CH_地图_2 {0x12,0x0000,2},//CH_马普_3} {0x13,0x0000,2},//CH_地图_4} //#0x20,0x1300,2}//Setup_Config_1 {0x20,0x0300,2},//Setup_Config_1 BI_UNIPOLAR0 {0x21, 0x1300, 2}, // Setup_ Config_ 2 {0x22,0x130,2},//Setup_Config_3}//Setup_Config_3 {0x23,0x130,2},//Setup_Config_4}//Setup_Config_4 {0x28, 0x020A, 2}, // filter_ Config_ 1 {0x29,0x020,2},//Filter_Config_2} {0x2a,0x020,2},//Filter_Config_3}//Filter_Config_3 {0.x2b, 0x0200, 2}, /// Filter_ Config_ 4 {0x30, 0, 3}, // offset_ 1 {0x31, 0, 3}, // offsets_ 2 {0x32, 0, 3}, // offset_ 3 { 0x33, 0, 3}, // offset_ 4 { 0x38, 0, 3}, // Gain_ 1 { 0x39, 0, 3}, // Gain_ 2 {0.x3a, 0, 3}, // Gain_ 3} {0.x3b, 0, 3}, // Gain_ 4 {0xFF,0,1}//通讯_登记 |
GMT+8, 2025-4-23 18:52 , Processed in 0.800946 second(s), Total 70, Slave 53 queries .
