本文是《【昉·星光 2 高性能RISC-V单板计算机体验】在昉·星光2上编译OpenWRT》的下篇,主要介绍如何基于编好的IMG文件烧入昉·星光 2 高性能RISC-V单板计算机并配置成一台真正可用的OpenWRT。
一、烧写固件
首先执行openwrt-jh71x0-generic-visionfive2-v1.3b-ext4-sdcard.img.gz
将压缩文件解压缩成img文件。
root@EliteDesk:~/wigyori/bin/targets/jh71x0/generic$ gunzip openwrt-jh71x0-generic-visionfive2-v1.3b-ext4-sdcard.img.gz
root@EliteDesk:~/wigyori/bin/targets/jh71x0/generic$ ls
config.buildinfo openwrt-jh71x0-generic-visionfive2-v1.3b-ext4-sdcard.img profiles.json
feeds.buildinfo openwrt-jh71x0-generic-visionfive2-v1.3b.manifest sha256sums
openwrt-jh71x0-generic-rootfs.cpio.gz packages version.buildinfo
插入tf卡并找到tf卡的设备名,本次设备名是/dev/sdb
,如下:
Disk /dev/sdb: 14.86 GiB, 15931539456 bytes, 31116288 sectors
Disk model: SD Card Reader
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 1EAB41CC-D75A-47CC-804D-CEB8295E2A38
Device Start End Sectors Size Type
/dev/sdb1 4096 8191 4096 2M HiFive Unleashed BBL
/dev/sdb2 8192 16383 8192 4M HiFive Unleashed FSBL
/dev/sdb3 16384 221183 204800 100M EFI System
/dev/sdb4 221184 8189918 7968735 3.8G Linux filesystem
最后执行命令sudo dd if=openwrt-jh71x0-generic-visionfive2-v1.3b-ext4-sdcard.img of=/dev/sdb bs=1M oflagirect
将img写入tf卡。
root@EliteDesk:~/wigyori/bin/targets/jh71x0/generic$ sudo dd if=openwrt-jh71x0-generic-visionfive2-v1.3b-ext4-sdcard.img of=/dev/sdb bs=1M oflagirect
197+1 records in
197+1 records out
206587685 bytes (207 MB, 197 MiB) copied, 13.3596 s, 15.5 MB/s
二、上电启动
连接好串口线,上电启动。
可以看出,之前编译内核选择的MT7601U驱动已经注册上。
[ 7.768106] kmodloader: loading kernel modules from /etc/modules.d/*
[ 7.797958] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 7.805455] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 8.095998] urngd: v1.0.2 started.
[ 8.942390] usbcore: registered new interface driver mt7601u
[ 9.076183] PPP generic driver version 2.4.2
[ 9.081267] NET: Registered PF_PPPOX protocol family
[ 9.089881] kmodloader: done loading kernel modules from /etc/modules.d/*
最后熟悉的欢迎界面。
看看系统版本。
三、配置系统
基本思路是把eth1配置成WAN口,eth0配置成LAN口,直接修改/etc/config/network
文件成如下内容(其中WAN6可以删除,没啥用途):
root@OpenWrt:/# cat /etc/config/network
config interface
option device
option proto
option ipaddr
option netmask
config globals
option ula_prefix
config device
option type
option name
list ports
config interface
option device
option proto
option ipaddr
option netmask
config interface
option device
option proto
config interface
option device
option proto
保存文件,并通过/etc/init.d/network restart
重启系统网络服务。然后使用ping工具简单测试下网路是否通畅:
一切OK,PC先断WiFi并通过双绞线连接至VF2的eth0继续测试,可以看到PC已经拿到LAN内IP,192.168.2.204。
这样,简单的OpenWRT已经运行起来。
四、系统体验
PC浏览器中敲入http://192.168.2.1/
登录openWRT管理系统。系统比之前RV社区发的那个IMG看起来版本要新,功能也多。
一进去reset好root密码后就是概览页,简洁明了。
实时状态看流量:
MT7601U设置启动并扫描无线信道,可以设置AP。
路由状态。
功能很多,一时半会无法尽数展示,最后来个PC侧跑网速测试。
最后、一些感受
来张全配置全连接合影图。
新的系统运行已超过24小时,期间PC一直在各种操作,包括高速下载,一切感受正常,系统也很稳定,可能冬天的关系,SoC没加散热片也能正常工作。
最后感谢StarFive & Elecfans提供的试用机会。
向从MIPS到RISC-V奉献的大佬们致敬。
