我这边使用S32K314的SPI Slave DMA功能发送数据遇到一个问题,SPI采用SPI0,TX DMA0 RX DMA1。
SPI需要传输1024个字节,发送数据第一帧数据正常,后续帧都会出现前4个字节都会被随机覆盖,其他1020个数据正常。 例如, 发送 AA 55 00 01 01 02 03 04 ... 通过逻辑分析仪抓包数据为 XX XX XX XX 01 02 03 04 ... SPI和Tx DMA初始化配置: LPSPI0_CLK_ENABLE(); IP_LPSPI_0->CFGR1 = LPSPI_CFGR1_MASTER(0) | LPSPI_CFGR1_PINCFG(0) | LPSPI_CFGR1_OUTCFG(0) | LPSPI_CFGR1_PCSCFG(0) | LPSPI_CFGR1_MATCFG(0) | LPSPI_CFGR1_PCSPOL(0) | LPSPI_CFGR1_NOSTALL(0); IP_LPSPI_0->FCR = LPSPI_FCR_RXWATER(0) | LPSPI_FCR_TXWATER(0); IP_LPSPI_0->TCR = LPSPI_TCR_CPOL(1) | LPSPI_TCR_CPHA(1) | LPSPI_TCR_PCS(1) | LPSPI_TCR_LSBF(0) | LPSPI_TCR_BYSW(1) | LPSPI_TCR_CONT(0) | LPSPI_TCR_CONTC(0) | LPSPI_TCR_TXMSK(0) | LPSPI_TCR_RXMSK(0) LPSPI_TCR_FRAMESZ(31 - 1) | LPSPI_TCR_WIDTH(0); IP_LPSPI_0->CR = LPSPI_CR_MEN(1); DMA_CLK_ENABLE(); DMAMUX_0_CLK_ENABLE(); DMA_TCD0_CLK_ENABLE(); IP_DMAMUX_0->CFCFG[3] = DMAMUX_CHCFG_SOURCE(43); NVIC_EnableIRQ((IRQn_Type)(DMATCD0_IRQn)); SPI和Tx DMA发送前配置: IP_LPSPI_0->CR |= LPSPI_CR_RRF_MASK | LPSPI_CR_RTF_MASK; IP_LPSPI_0->DER = ~(LPSPI_DER_TDDE_MASK | LPSPI_DER_RDDE_MASK); IP_TCD->TCD0_SADDR = (uint32_t)SrcAddr; IP_TCD->TCD0_DADDR = (uint32_t) IP_LPSPI_0->TDR; IP_TCD->TCD0_ATTR = DMA_TCD_TCD0_ATTR_SMOD(0) | DMA_TCD_TCD0_ATTR_SSIZE(2) | DMA_TCD_TCD0_ATTR_DMOD(0) | DMA_TCD_TCD0_ATTR_DSIZE(2); IP_TCD->TCD0_SOFF = 4; IP_TCD->TCD0_DOFF = 0; IP_TCD->NBYTES0.TCD0_NBYTES_MLOFFNO = 4; IP_TCD->BITER0.TCD0_BITER_ELINKNO = DMA_TCD_TCD0_BITER_ELINKNO_BITER(256); IP_TCD->CITER0.TCD0_CITER_ELINKNO = DMA_TCD_TCD0_CITER_ELINKNO_CITER(256); IP_TCD->TCD0_SLAST_SDA = 0; IP_TCD->TCD0_DLAST_SGA = 0; IP_TCD->TCD0_CSR |= DMA_TCD_TCD0_CSR_INTMAJOR(1) ~DMA_TCD_TCD0_CSR_START_MASK; IP_LPSPI_0->DER |= LPSPI_DER_TDDE_MASK | LPSPI_DER_RDDE_MASK; IP_TCD->CH0_INT = DMA_TCD_CH0_INT_INT(0); IP_TCD->CH0_CSR = DMA_TCD_CH0_CSR_ERQ(1); IP_DMAMUX_0->CFCFG[3] |= DMAMUX_CHCFG_ENBL_MASK; TX Dma中断函数: void DMA0_IRQHandler(void) { IP_LPSPI_0->DER = ~LPSPI_DER_TDDE_MASK; LP_LPSPI_0->CR |= LPSPI_CR_RTF_MASK; IP_LPSPI_0->CH0_CSR |= DMA_TCD_CH0_CSR_DONE(1); IP_LPSPI_0->CH0_INT |= DMA_TCD_CH0_INT_INT(1); IP_DMAMUX_0->CFCFG[3] = ~DMAMUX_CHCFG_ENBL_MASK; IP_TCD->CH0_CSR = DMA_TCD_CH0_CSR_ERQ(0); Spi0_TxHandler(); } |
1964个成员聚集在这个小组
36573 浏览 0 评论
5979 浏览 1 评论
6247 浏览 1 评论
6939 浏览 0 评论
4326 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-24 22:16 , Processed in 0.787845 second(s), Total 42, Slave 37 queries .
