使用C8051F的单片机来实现CAN控制,可以进行数据的接收,发送不行
void CAN0_TransferMO (U8 obj_num){ // This function assumes that the message object is fully initialized // in CAN0_Init and so all it has to do is fill the data registers and // initiate transmission U8 SFRPAGE_save = SFRPAGE; SFRPAGE = CAN0_PAGE; // All CAN register are on page 0x0C // Initialize all 8 data bytes even though they might not be sent // The number to send was configured earlier by setting Message Control CAN0IF1DA1H = obj_num; // Initialize data registers based CAN0IF1DA1L = obj_num + 1; // on message object used CAN0IF1DA2H = obj_num + 2; CAN0IF1DA2L = obj_num + 3; CAN0IF1DB1H = obj_num + 4; CAN0IF1DB1L = obj_num + 5; CAN0IF1DB2H = obj_num + 6; CAN0IF1DB2L = obj_num + 7; CAN0IF1CM = 0x0087; // Set Direction to Write // Write TxRqst all 8 data bytes CAN0IF1CR = obj_num; // Start command request while (CAN0IF1CRH 0x80); // Poll on Busy bit SFRPAGE = SFRPAGE_save;} |
8051本身没有CAN的收发器吧,必须要外接TTL转CAN的收发芯片才行,况且这种芯片的通信速度要求很高的,8051的速度远远不够。
esp8266作为tcp客户端,服务器主动断开连接后,是会主动重连吗,如何设置不要主动重连呢
596 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-platform总线驱动简单示例
641 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第六十章 猫脸检测实验
929 浏览 2 评论
1117 浏览 2 评论
722 浏览 0 评论
12727 浏览 31 评论
GMT+8, 2025-4-4 12:59 , Processed in 0.634988 second(s), Total 71, Slave 55 queries .
