扫一扫,分享给好友
运行RetinaFace对应用例 retinaface_bmcv,编译生成 retinaface_bmcv.pcie,然后运行: ./retinaface_bmcv.pcie 0 ../../../data/images/face ../../../data/models/BM1684/retinaface_mobilenet0.25_fp32_1b.bmodel,程序出现segment fault,如附件现象所示。
于是,加入调测打印,发现调用imread接口读入jpg图像时,出现问题。 查找资料,发现 Mat imread(const String filename, int flags, int id ) 接口,是在特定卡上运行硬件加速功能进行改写后的接口,不是原生opencv接口。 查看当前opencv version以及安装sophon相关dev包如下: linaro@BM1684-180:/data/young/sophonsdk/Release_230501-public/sophon-demo_20230605_085900/sophon-demo_ v0.1.6_f4d1abc_20230605/sample/RetinaFace/data/images/face$ opencv_version 4.1.0 dpkg -l | grep sophon ii sophon-driver 0.4.8 arm64 libsophon buil t using CMake ii sophon-libsophon 0.4.8 arm64 libsophon buil t using CMake ii sophon-mw-soc-sophon-ffmpeg 0.6.3 arm64 Sophon multime dia library ii sophon-mw-soc-sophon-ffmpeg-dev 0.6.3 arm64 Sophon multime dia library ii sophon-mw-soc-sophon-opencv 0.6.3 arm64 Sophon multime dia library ii sophon-mw-soc-sophon-opencv-dev 0.6.3 arm64 Sophon multime dia library ii sophon-mw-sophon-ffmpeg 0.6.3 arm64 Sophon multime dia library ii sophon-mw-sophon-opencv 0.6.3 arm64 Sophon multime dia library ii sophon-soc-libsophon 0.4.8 arm64 libsophon buil t using CMake ii sophon-soc-libsophon-dev 0.4.8 arm64 libsophon buil t using CMake 当前使用sdk版本为Release_230501-public,帮忙解答下为何改写opencv接口imread调用会出错? |
H264硬编码CVI_VENC_StartRecvFrame报错的原因?怎么解决?
617浏览 2评论
使用bm-smi查看信息时发现没有程序运行但是设备内存被占用是怎么回事?
352浏览 1评论
361浏览 1评论
SE5盒子如何修改IP?执行bm_set_ip提示没有该命令?
361浏览 1评论
765浏览 1评论
GMT+8, 2025-2-2 00:03 , Processed in 0.344513 second(s), Total 40, Slave 35 queries .
