#include "MS51_16K.H"
/* if define tiMER0_FSYS_DIV12, timer = (0x1FFF-0x1000)*12/24MHz = 4.08ms */ /* if define TIMER0_FSYS, timer = (0x1FFF-0x0010)/24MHz = 340us */ #define TH0_INIT 0x00 #define TL0_INIT 0x10 /************************************************************************************************************ * TIMER 0 interrupt subroutine ************************************************************************************************************/ void Timer0_ISR (void) interrupt 1 /*interrupt address is 0x000B */ { _push_(SFRS); TH0 = TH0_INIT; TL0 = TL0_INIT; TF0 = 0 ; P12 = ~P12; /* GPIO toggle when interrupt */ _pop_(SFRS); } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { P12_PUSHPULL_MODE; ENABLE_TIMER1_MODE0; /* Timer 0 mode configuration */ TIMER0_FSYS_DIV12; TH0 = TH0_INIT; TL0 = TL0_INIT; ENABLE_TIMER0_INTERRUPT; /* enable Timer0 interrupt */ ENABLE_GLOBAL_INTERRUPT; /* enable interrupts */ set_TCON_TR0; /* Timer0 run */ while(1); } |
要加,因为MS51的SRF涉及到多个页,否则可能会导致寄存器操作错误
GMT+8, 2025-2-2 12:20 , Processed in 0.479415 second(s), Total 45, Slave 39 queries .
