环境:
开发版: M483KG usb转uart: PL 2303/ FT 232 目的: 如何使用HSUSBH_USBH_VCOM 读写PL2303/ FT 232? 问题: 插拔PL2303/FR232装置,会显示Connect device, disconnect device 但是不知道如何传收资料。 讯息如下: +---------------------------------------------------------+ | M480 USB Host VCOM sample program | +---------------------------------------------------------+ | (NOTE: This sample supports only one CDC device, but | | driver supports multiple CDC devices. If you | | want to support multiple CDC devices, you | | have to modify this sample. | +---------------------------------------------------------+ USB static memory: 6/256, heap used: 0 Connect device => New full-speed device address 2 assigned. USB static memory: 7/256, heap used: 568 disconnect device... USB static memory: 6/256, heap used: 0 USB static memory: 6/256, heap used: 0 Connect device => New full-speed device address 3 assigned. USB static memory: 7/256, heap used: 568 disconnect device... USB static memory: 6/256, heap used: 0 USB static memory: 6/256, heap used: 0 Connect device => New full-speed device address 4 assigned. USB static memory: 7/256, heap used: 568 |
开发板通过仿真器连接到电脑,电脑上打开串口调试工具。 串口调试工具发送数据,MCU收到后通过USB转发出去
GMT+8, 2024-12-25 12:36 , Processed in 0.460620 second(s), Total 45, Slave 40 queries .
