我用MPLAB写的PIC单片机的程序 ,我编译的时候有时候能够成功 有时候出现下面的错误 ,但只要多编译几次就正确了。 联接的时候出现同样的错误, 但是多次联接错误任然会有错误 且错误都是指向C盘下的头文件目录中 希望哪位朋友能解释一下啊 非常感谢了
Executing: "C:Program FilesHI-TECH SoftwarePICCPRO9.65binpicc.exe" --pass1 E:nRF24L01_drivenRF24L01_drive.c -q --chip=16F690 -P --runtime=default,+clear,+init,+keep,+osccal,-download,-resetbits,+stackcall,+stackwarn,+clib --opt=default,+asm,9 --warn=0 --double=24 --addrqual=ignore -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s" Error [285] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 24.24 no identifier in declaration Error [314] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 24.24 ";" expected Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 124.38 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 124.43 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 125.35 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 125.40 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 126.37 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 126.42 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 127.35 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 127.40 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 128.35 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 128.40 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 129.27 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 129.32 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 130.27 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 130.32 simple integer expression required Error [201] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 131.27 taking the address of this object is illegal Error [236] C:Program FilesHI-TECH SoftwarePICCPRO9.65includepic16f685.h; 131.32 simple integer expression required ********** Build failed! ********** |
求解外围电路实现的是4脚给持续低电平复位并正常工作,高电平不工作的原因
2121 浏览 1 评论
3684 浏览 3 评论
PIC1946程序有一个变量在运行过程中恢复初始值其他变量保持不变
2366 浏览 2 评论
2796 浏览 0 评论
PIC16F1825的RC5引脚,在主程序中操作无效,在中断中可以改变是为什么?
4098 浏览 5 评论
1040浏览 0评论
用XC8编译PIC18F25K80时提示下面Error,求怎么解决这个问题
6416浏览 0评论
GMT+8, 2025-1-13 03:47 , Processed in 0.523328 second(s), Total 80, Slave 61 queries .
