现在我正在学习使用 NUC029SGE 芯片与带有 PDMA SPI 的 ws2812 一起使用 http://www.nuvoton-mcu.com/forum ... mp;highlight=ws2812
即使在修復错误之后它也不起作用,我尝试了链接中的示例。
https://m.blog.naver.com/PostVie ... ;logNo=221544870211
使用 SPI FIFO Master 不再起作用。
我正在尝试订阅 论坛寻求帮助。 http://www.nuvoton-mcu.com/forum已经用邮箱註册了[url=mailto itipong@narit.or.th]Pi tipong@narit.or.th[/url]我没有收到系统的回应,而且确认不是机器人的身份使用了汉字,汉字,让我无法使用。我真的需要管理员的帮助,我想使用 nuvoton 芯片,它工作正常,请管理员帮助我。我觉得新唐芯片在泰国市场有很大的前途,5-6年前,新唐芯片和ST或者NXP价格相差不大,但是现在价格差距很大。我想做新唐芯片,也想卖给泰国人用。
谢谢你
我试图实现的代码 spi fifo
- * @file main.c
- * @version V3.0
- * $Revision: 3 $
- * $Date: 17/05/04 1:53p $
- * @brief Configure SPI0 as Master mode and demonstrate how to communicate
- * with an off-chip SPI Slave device with FIFO mode. This sample
- * code needs to work with SPI_SlaveFifoMode sample code.
- * @note
- * Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
- #include
- #include "NUC029xGE.h"
- #define MAX_LED_COUNT 50
- uint8_t leds[MAX_LED_COUNT][3] = {{0x00, 0x00, 0x00},{0x00, 0x00, 0x00},};
- uint8_t ledCount=0;
- uint8_t ledTotalCount=0;
- uint8_t colorCount=0;
- const uint32_t colorLookup[] = {
- 0x924924, 0x924926, 0x924934, 0x924936, 0x9249A4, 0x9249A6, 0x9249B4, 0x9249B6, 0x924D24, 0x924D26, 0x924D34, 0x924D36, 0x924DA4, 0x924DA6, 0x924DB4, 0x924DB6,
- 0x926924, 0x926926, 0x926934, 0x926936, 0x9269A4, 0x9269A6, 0x9269B4, 0x9269B6, 0x926D24, 0x926D26, 0x926D34, 0x926D36, 0x926DA4, 0x926DA6, 0x926DB4, 0x926DB6,
- 0x934924, 0x934926, 0x934934, 0x934936, 0x9349A4, 0x9349A6, 0x9349B4, 0x9349B6, 0x934D24, 0x934D26, 0x934D34, 0x934D36, 0x934DA4, 0x934DA6, 0x934DB4, 0x934DB6,
- 0x936924, 0x936926, 0x936934, 0x936936, 0x9369A4, 0x9369A6, 0x9369B4, 0x9369B6, 0x936D24, 0x936D26, 0x936D34, 0x936D36, 0x936DA4, 0x936DA6, 0x936DB4, 0x936DB6,
- 0x9A4924, 0x9A4926, 0x9A4934, 0x9A4936, 0x9A49A4, 0x9A49A6, 0x9A49B4, 0x9A49B6, 0x9A4D24, 0x9A4D26, 0x9A4D34, 0x9A4D36, 0x9A4DA4, 0x9A4DA6, 0x9A4DB4, 0x9A4DB6,
- 0x9A6924, 0x9A6926, 0x9A6934, 0x9A6936, 0x9A69A4, 0x9A69A6, 0x9A69B4, 0x9A69B6, 0x9A6D24, 0x9A6D26, 0x9A6D34, 0x9A6D36, 0x9A6DA4, 0x9A6DA6, 0x9A6DB4, 0x9A6DB6,
- 0x9B4924, 0x9B4926, 0x9B4934, 0x9B4936, 0x9B49A4, 0x9B49A6, 0x9B49B4, 0x9B49B6, 0x9B4D24, 0x9B4D26, 0x9B4D34, 0x9B4D36, 0x9B4DA4, 0x9B4DA6, 0x9B4DB4, 0x9B4DB6,
- 0x9B6924, 0x9B6926, 0x9B6934, 0x9B6936, 0x9B69A4, 0x9B69A6, 0x9B69B4, 0x9B69B6, 0x9B6D24, 0x9B6D26, 0x9B6D34, 0x9B6D36, 0x9B6DA4, 0x9B6DA6, 0x9B6DB4, 0x9B6DB6,
- 0xD24924, 0xD24926, 0xD24934, 0xD24936, 0xD249A4, 0xD249A6, 0xD249B4, 0xD249B6, 0xD24D24, 0xD24D26, 0xD24D34, 0xD24D36, 0xD24DA4, 0xD24DA6, 0xD24DB4, 0xD24DB6,
- 0xD26924, 0xD26926, 0xD26934, 0xD26936, 0xD269A4, 0xD269A6, 0xD269B4, 0xD269B6, 0xD26D24, 0xD26D26, 0xD26D34, 0xD26D36, 0xD26DA4, 0xD26DA6, 0xD26DB4, 0xD26DB6,
- 0xD34924, 0xD34926, 0xD34934, 0xD34936, 0xD349A4, 0xD349A6, 0xD349B4, 0xD349B6, 0xD34D24, 0xD34D26, 0xD34D34, 0xD34D36, 0xD34DA4, 0xD34DA6, 0xD34DB4, 0xD34DB6,
- 0xD36924, 0xD36926, 0xD36934, 0xD36936, 0xD369A4, 0xD369A6, 0xD369B4, 0xD369B6, 0xD36D24, 0xD36D26, 0xD36D34, 0xD36D36, 0xD36DA4, 0xD36DA6, 0xD36DB4, 0xD36DB6,
- 0xDA4924, 0xDA4926, 0xDA4934, 0xDA4936, 0xDA49A4, 0xDA49A6, 0xDA49B4, 0xDA49B6, 0xDA4D24, 0xDA4D26, 0xDA4D34, 0xDA4D36, 0xDA4DA4, 0xDA4DA6, 0xDA4DB4, 0xDA4DB6,
- 0xDA6924, 0xDA6926, 0xDA6934, 0xDA6936, 0xDA69A4, 0xDA69A6, 0xDA69B4, 0xDA69B6, 0xDA6D24, 0xDA6D26, 0xDA6D34, 0xDA6D36, 0xDA6DA4, 0xDA6DA6, 0xDA6DB4, 0xDA6DB6,
- 0xDB4924, 0xDB4926, 0xDB4934, 0xDB4936, 0xDB49A4, 0xDB49A6, 0xDB49B4, 0xDB49B6, 0xDB4D24, 0xDB4D26, 0xDB4D34, 0xDB4D36, 0xDB4DA4, 0xDB4DA6, 0xDB4DB4, 0xDB4DB6,
- 0xDB6924, 0xDB6926, 0xDB6934, 0xDB6936, 0xDB69A4, 0xDB69A6, 0xDB69B4, 0xDB69B6, 0xDB6D24, 0xDB6D26, 0xDB6D34, 0xDB6D36, 0xDB6DA4, 0xDB6DA6, 0xDB6DB4, 0xDB6DB6,
- void setTotalPixels(uint8_t total)
- if(total >= MAX_LED_COUNT)
- ledTotalCount = MAX_LED_COUNT;
- else
- ledTotalCount = total;
- void setPixel(uint8_t id, uint8_t r, uint8_t g, uint8_t b)
- if(id >= MAX_LED_COUNT){
- return;}
- leds[id][0] = r;
- leds[id][1] = g;
- leds[id][2] = b;
- void getPixel(uint8_t id, uint8_t *r, uint8_t *g, uint8_t *b)
- return;}
- *r = leds[id][0];
- *g = leds[id][1];
- *b = leds[id][2];
- void showLED()
- ledCount=0;
- colorCount=0;
- SPI_EnableInt(SPI0, SPI_FIFOCTL_TXTHIEN_Msk);
- /* Function prototype declaration */
- void SYS_Init(void);
- void SPI_Init(void);
- /* Main function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O. */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
- UART_Open(UART0, 115200);
- SPI_Init();
- printf("\n\n");
- printf("+----------------------------------------------------------------------+\n");
- setTotalPixels(8);
- printf("\nt");
- while(1){
- setPixel(0,255,0,0);
- showLED();
- setPixel(1,255,0,0);
- showLED();
- setPixel(2,255,0,0);
- showLED();
- setPixel(3,255,0,0);
- showLED();
- /* Init System Clock */
- /* Enable external 12MHz XTAL */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- /* Switch HCLK clock source to HXT and set HCLK divider to 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT, CLK_CLKDIV0_HCLK(1));
- /* Select HXT as the clock source of UART0 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
- /* Select PCLK0 as the clock source of SPI0 */
- CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL2_SPI0SEL_PCLK0, MODULE_NoMsk);
- /* Enable UART peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable SPI0 peripheral clock */
- CLK_EnableModuleClock(SPI0_MODULE);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set multi-function pins for UART0 RXD and TXD */
- SYS->GPA_MFPL = ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
- SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
- /* Setup SPI0 multi-function pins */
- SYS->GPB_MFPL = ~(SYS_GPB_MFPL_PB4MFP_Msk | SYS_GPB_MFPL_PB5MFP_Msk | SYS_GPB_MFPL_PB6MFP_Msk | SYS_GPB_MFPL_PB7MFP_Msk);
- SYS->GPB_MFPL |= SYS_GPB_MFPL_PB4MFP_SPI0_SS | SYS_GPB_MFPL_PB5MFP_SPI0_MOSI | SYS_GPB_MFPL_PB6MFP_SPI0_MISO | SYS_GPB_MFPL_PB7MFP_SPI0_CLK;
- /* Init SPI */
- printf("\ns");
- SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 24, 2400000);
- SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_HIGH);
- SPI_SetFIFO(SPI0, 3, 2);
- NVIC_EnableIRQ(SPI0_IRQn);
- void SPI0_IRQHandler(void)
- /* Check TX FULL flag and TX data count */
- printf("\np");
- if((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) (ledCount < ledTotalCount))
- /* Write to TX FIFO */
- SPI_WRITE_TX(SPI0, colorLookup[leds[ledCount][colorCount++]]);
- printf("\nx");
- if(colorCount >= 3)
- //ledCount ??
- ledCount++;
- //led ?? ??? ? ???
- colorCount=0;
- }else{
- ledCount=0;
- colorCount=0;
- SPI_DisableInt(SPI0, SPI_FIFOCTL_TXTHIEN_Msk); /* Disable TX FIFO threshold interrupt */
