按照https://www.rvmcu.com/community-topic-id-369.html说明安装驱动后,图示标注3处仍未显示jtag-debugger,同时Eclipse run 失败,感觉是不是还是由于没有显示jtag-debugger导致的呢?系统win10,开发板型号HUMMINGBIRD Evaluation Kit,调试器型号HUMMINGBIRD Debugger Kit。
Eclipse run 错误信息如下: GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00084-gae68d7da-dirty (2018-09-26-15:32) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html adapter speed: 1000 kHz Info : auto-selecting first available session transport "jtag". To override use 'transport select '. Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED Info : clock speed 1000 kHz Error: JTAG scan chain interrogation failed: all ones Error: Check JTAG interface, timings, target power, etc. Error: Trying to use configured scan chain anyway... Error: riscv.cpu: IR capture error; saw 0x1f not 0x01 Warn : Bypassing JTAG setup events due to errors Error: Unsupported DTM version: 15 Info : Listening on port 3333 for gdb connections Error: Target not examined yet Error: Unsupported DTM version: 15 Warn : Flash driver of my_first_flash does not support free_driver_priv() |
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
442 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
593 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
635 浏览 1 评论
GMT+8, 2025-2-24 14:56 , Processed in 0.677920 second(s), Total 74, Slave 58 queries .
