在学习“Nuclei™ N100 系列处理器内核快速集成手册”时,在第6章进行实验出错warning
------------------------------------------------------------------------------------------------------------------------------------------ Warning-[STASKW_RMIEAFL] Illegal entry /home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_mem_init.v, 28 Illegal entry found at file /home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc.verilog line 1 while executing $readmem. Please ensure that the file has proper entries. ILM 0x00: xxxxxxxx ILM 0x01: xxxxxxxx ILM 0x02: xxxxxxxx ILM 0x03: xxxxxxxx ILM 0x04: xxxxxxxx ILM 0x05: xxxxxxxx ILM 0x06: xxxxxxxx ILM 0x07: xxxxxxxx ILM 0x16: xxxxxxxx ILM 0x20: xxxxxxxx SEED = 20210812225456 FORCE_DELAY= 0 *Verdi3* Loading libsscore_vcs201606.so *Verdi3* : FSDB_GATE is set. *Verdi3* : FSDB_RTL is set. *Verdi3* : Enable Parallel Dumping. FSDB Dumper for VCS, Release Verdi3_L-2016.06-1, Linux x86_64/64bit, 07/10/2016 (C) 1996 - 2016 by Synopsys, Inc. *Verdi3* : Create FSDB file 'tb_top.fsdb' *Verdi3* : Begin traversing the scope (tb_top), layer (0). *Verdi3* : Enable +mda dumping. *Verdi3* : End of traversing. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TESTCASE= /home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc FORCE_IRQ= 0 FORCE_RESP_ERR= 0 WFI_FORCE_IRQ= 1 Warning-[STASKW_RMIEAFL] Illegal entry /home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_mem_init.v, 70 Illegal entry found at file /home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc.verilog line 1 while executing $readmem. Please ensure that the file has proper entries. Warning-[STASKW_RMIEAFL] Illegal entry /home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_mem_init.v, 70 Illegal entry found at file /home/xiaotu/riscv/n101_cct/vsim/demo_irqc/demo_irqc.verilog line 1 while executing $readmem. Please ensure that the file has proper entries. Time Out !!! $finish called from file "/home/xiaotu/riscv/n101_cct/vsim/run/../install/tb/tb_top.v", line 145. $finish at simulation time 20000000000 V C S S i m u l a t i o n R e p o r t Time: 200000000000 ps CPU Time: 12.950 seconds; Data structure size: 2.8Mb Thu Aug 12 22:55:12 2021 make[1]: Leaving directory `/home/xiaotu/riscv/n101_cct/vsim/run' -------------------------------------------------------------------------------------------------------------------------------------------------- 步骤一二三均可正确执行,但到第四步make run_test TESTCASE=$PWD/demo_irqc/demo_irqc,就出warning。 运行case=rv32ui-p-add就没有问题显示PASS,“demo_irqc.verilog”与“rv32ui-p-add.verilog”文件里面的16进制格式写法一样,但是一个行,一个不行。 是在不清楚问题出在哪里?! |
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
406 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
549 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
575 浏览 1 评论
GMT+8, 2024-12-24 01:26 , Processed in 0.403122 second(s), Total 43, Slave 38 queries .
