Model Optimizer version: 2019.3.0-375-g332562022
[ ERROR ] ------------------------------------------------- [ ERROR ] ----------------- INTERNAL ERROR ---------------- [ ERROR ] Unexpected exception happened. [ ERROR ] Please contact Model Optimizer developers and forward the following information: [ ERROR ] 'Graph' object has no attribute 'node' [ ERROR ] Traceback (most recent call last): File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/main.py", line 302, in main return driver(argv) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/main.py", line 261, in driver custom_layers_mapping_path=custom_layers_mapping_path) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/pipeline/caffe.py", line 65, in driver graph, original_shapes = loader.caffe_pb_to_nx(proto, model) File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/front/caffe/loader.py", line 294, in caffe_pb_to_nx graph.add_node(layer.name, pb=layer, model_pb=model_layer, kind='op', type='Parameter') File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 505, in add_node node.update_node() File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 470, in update_node in_ports_count = self.in_ports_count if self.has_valid('in_ports_count') else None File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 161, in has_valid return self.has(k) and not self.graph.node[self.node][k] is None File "/opt/intel/openvino_2019.3.334/deployment_tools/model_optimizer/mo/graph/graph.py", line 158, in has return k in self.graph.node[self.node] AttributeError: 'Graph' object has no attribute 'node' [ ERROR ] ---------------- END OF BUG REPORT -------------- [ ERROR ] ------------------------------------------------- 模型优化器与 Python * NetworkX package 版本2.4 存在兼容性问题。 |
3个成员聚集在这个小组
加入小组257浏览 1评论
在DL Workbench 2022.1中转换模型时遇到的错误问题
346浏览 1评论
使用OpenVINO推断时收到ImportError: DLL load failed while importing ie_api错误
453浏览 1评论
如何将PyTorch模型与OpenVINO trade结合使用?
1033浏览 1评论
求助,无法找到rdquo;OpenCV ldquo提供的封装配置文件求分享
584浏览 1评论
GMT+8, 2025-2-23 12:58 , Processed in 0.578382 second(s), Total 75, Slave 59 queries .
