MCU 芯来调试器下载Hellow World例程 报错如下,无法调试,求大佬解决!!!
Nuclei OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev-00036-gbfc178ffb (2021-02-01-06:41) Licensed under GNU GPL v2 For bug reports, read Info : Using libusb driver Info : clock speed 1000 kHz Info : JTAG tap: riscv.cpu tap/device found: 0x13636093 (mfg: 0x049 (Xilinx), part: 0x3636, ver: 0x1) Info : Exposing additional CSR 770 Info : Exposing additional CSR 771 Info : Exposing additional CSR 775 Info : Exposing additional CSR 776 Info : Exposing additional CSR 777 Info : Exposing additional CSR 778 Info : Exposing additional CSR 779 Info : Exposing additional CSR 780 Info : Exposing additional CSR 781 Info : Exposing additional CSR 782 Info : Exposing additional CSR 783 Info : Exposing additional CSR 784 Info : Exposing additional CSR 785 Info : Exposing additional CSR 786 Info : Exposing additional CSR 787 Info : Exposing additional CSR 788 Info : Exposing additional CSR 789 Info : Exposing additional CSR 790 Info : Exposing additional CSR 791 Info : Exposing additional CSR 792 Info : Exposing additional CSR 793 Info : Exposing additional CSR 794 Info : Exposing additional CSR 795 Info : Exposing additional CSR 796 Info : Exposing additional CSR 797 Info : Exposing additional CSR 798 Info : Exposing additional CSR 799 Info : Exposing additional CSR 800 Info : Exposing additional CSR 837 Info : Exposing additional CSR 838 Info : Exposing additional CSR 839 Info : Exposing additional CSR 840 Info : Exposing additional CSR 841 Info : Exposing additional CSR 842 Info : Exposing additional CSR 843 Info : Exposing additional CSR 844 Info : Exposing additional CSR 845 Info : Exposing additional CSR 846 Info : Exposing additional CSR 847 Info : Exposing additional CSR 848 Info : Exposing additional CSR 849 Info : Exposing additional CSR 850 Info : Exposing additional CSR 1984 Info : Exposing additional CSR 1985 Info : Exposing additional CSR 1986 Info : Exposing additional CSR 1987 Info : Exposing additional CSR 1988 Info : Exposing additional CSR 1989 Info : Exposing additional CSR 1990 Info : Exposing additional CSR 1991 Info : Exposing additional CSR 1992 Info : Exposing additional CSR 1993 Info : Exposing additional CSR 1994 Info : Exposing additional CSR 1995 Info : Exposing additional CSR 1996 Info : Exposing additional CSR 1997 Info : Exposing additional CSR 1998 Info : Exposing additional CSR 1999 Info : Exposing additional CSR 2000 Info : Exposing additional CSR 2001 Info : Exposing additional CSR 2002 Info : Exposing additional CSR 2003 Info : Exposing additional CSR 2004 Info : Exposing additional CSR 2005 Info : Exposing additional CSR 2006 Info : Exposing additional CSR 2007 Info : Exposing additional CSR 2008 Info : Exposing additional CSR 2009 Info : Exposing additional CSR 2010 Info : Exposing additional CSR 2011 Info : Exposing additional CSR 2012 Info : Exposing additional CSR 2013 Info : Exposing additional CSR 2014 Info : Exposing additional CSR 2015 Info : Exposing additional CSR 2016 Info : Exposing additional CSR 2017 Info : Exposing additional CSR 2018 Info : Exposing additional CSR 2019 Info : Exposing additional CSR 2020 Info : Exposing additional CSR 2021 Info : Exposing additional CSR 2022 Info : Exposing additional CSR 2023 Info : Exposing additional CSR 2024 Info : Exposing additional CSR 2025 Info : Exposing additional CSR 2026 Info : Exposing additional CSR 2027 Info : Exposing additional CSR 2028 Info : Exposing additional CSR 2029 Info : Exposing additional CSR 2030 Info : Exposing additional CSR 2031 Info : Exposing additional CSR 2032 Info : Exposing additional CSR 2064 Info : Exposing additional CSR 2065 Info : Exposing additional CSR 2066 Info : Exposing additional CSR 2067 Info : Exposing additional CSR 2068 Info : Exposing additional CSR 2069 Info : Exposing additional CSR 2070 Error: dtmcontrol is 0. Check JTAG connectivity/board power. Info : Listening on port 3333 for gdb connections Error: Target not examined yet |
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
485 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
638 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
687 浏览 1 评论
GMT+8, 2025-4-22 05:10 , Processed in 0.611576 second(s), Total 73, Slave 57 queries .
