使用了自己的FPGA开发板,通过普通的IO实现jtag调试器连接,FPGA顶层的引脚如下图所示
其中qspi引脚用的是FPGA固化程序用的flash 而下载器则是通过淘宝上购买的一个sispeed USB转JTAG+UART的下载器 然后在nuclei studio上选择的是sdk-hbird_sdk @0.1.3 在点击debug 下面是各种报错信息 下面两张图是成功的那次的报错信息,是经过无数debug,然后某次串口突然停止输出了(平时一般一直输出0),然后按下mcu复位按键,就实现了下载成功,但也只成功过这一次 另外通过debug,在烧写FPGA程序时候,观察一下信号,inspect_pc一直处于0和2,然后nuclei studio下载后指令变化了,FPGA上观察到的指令值对比了一下.verilog文件的指令值是一样的,说明还是有程序写进去了,但是还是一直报错,串口也无法输出打印的信息 DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’ DEPRECATED! use ‘adapter driver’ not ‘interface’ DEPRECATED! use ‘ftdi vid_pid’ not ‘ftdi_vid_pid’ DEPRECATED! use ‘ftdi oscan1_mode’ not ‘ftdi_oscan1_mode’ DEPRECATED! use ‘ftdi layout_init’ not ‘ftdi_layout_init’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’ Info : libusb_open() failed with LIBUSB_ERROR_NOT_FOUND Info : no device found, trying D2xx driver Info : D2xx device count: 2 Info : Connecting to “(null)” using D2xx mode… Info : clock speed 1000 kHz Info : JTAG tap: riscv.cpu tap/device found: 0x1e200a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0xe200, ver: 0x1) Info : Examined RISCV core; XLEN=32, misa=0x40001105 [riscv.cpu] Target successfully examined. Info : starting gdb server for riscv.cpu on 3333 Info : Listening on port 3333 for gdb connections Info : [riscv.cpu] Found 0 triggers halted at 0x0 due to debug interrupt Info : Valid NUSPI on device Nuclei SoC SPI Flash at address 0x20000000 with spictrl regbase at 0x10014000 Info : Nuclei SPI controller version 0x00000000 Warn : Got exception 0x1000000 when writing t0 Error: nuspi_write_reg() error writing 0x0 to 0x10014048 Info : Found flash device ‘micron n25q128’ (ID 0x0018ba20) cleared protection for sectors 0 through 255 on flash bank 0 Started by GNU MCU Eclipse Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : accepting ‘gdb’ connection on tcp/3333 Warn : Prefer GDB command “target extended-remote :3333” instead of “target remote :3333” Info : JTAG tap: riscv.cpu tap/device found: 0x1e200a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0xe200, ver: 0x1) halted at 0x0 due to debug interrupt Info : Retrying memory write starting from 0x80000cc0 with more delays halted at 0x80000280 due to debug interrupt Warn : Got exception 0x10 when reading mstatus Error: Failed to read mstatus register. Info : dropped ‘gdb’ connection |
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
445 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
597 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
638 浏览 1 评论
GMT+8, 2025-3-5 04:47 , Processed in 0.595382 second(s), Total 71, Slave 55 queries .
