最近在了解ST MEMS麦克风的使用,有一个Audio_playback_and_record的工程,我的目的是想了解一下处理音频数据的过程,但是发现 int main()里找不到waverecorder.c文件中定义的函数 ,而且主函数中还多了加速度传感器的内容,让我很是疑惑,小白学艺不精,请问有大佬可以回答我下吗
主程序如下 /**
/ Configure the system clock to 168 MHz /SystemClock_Config(); / Initialize MEMS Accelerometer mounted on STM32F4-Discovery board /if(BSP_ACCELERO_Init() != ACCELERO_OK){/ Initialization Error /Error_Handler();} MemsID = BSP_ACCELERO_ReadID(); / Turn ON LED4: start of application /BSP_LED_On(LED4); / Configure TIM4 Peripheral to manage LEDs lighting /TIM_LED_Config(); / Initialize the Repeat state /RepeatState = REPEAT_ON; / Turn OFF all LEDs /LEDsState = LEDS_OFF; / Configure USER Button /BSP_PB_Init(BUTTON_KEY, BUTTON_MODE_EXTI); /##-1- Link the USB Host disk I/O driver ##################################/if(FATFS_LinkDriver( USBH_Driver, USBDISKPath) == 0){/##-2- Init Host Library ################################################/USBH_Init( hUSB_Host, USBH_UserProcess, 0); /##-3- Add Supported Class ##############################################/USBH_RegisterClass( hUSB_Host, USBH_MSC_CLASS); /##-4- Start Host Process ###############################################/USBH_Start( hUSB_Host); / Run Application (Blocking mode)/while (1){switch(AppliState){case APPLICATION_START:MSC_Application();break;case APPLICATION_IDLE:default:break;} / USBH_Background Process /USBH_Process( hUSB_Host);}} / TrueStudio compilation error correction /while (1){}} waverecorder.c里定义的函数如下图: |
定义的函数不一定非要在主函数中直接调用的,也许是通过主函数中调用的某个函数中调用,那在主函数中就不能直接看到。
2906 浏览 1 评论
3290 浏览 1 评论
1870 浏览 1 评论
3724 浏览 6 评论
6134 浏览 21 评论
GMT+8, 2025-3-9 22:11 , Processed in 0.389523 second(s), Total 43, Slave 38 queries .
