define MAX6675_CS_Pin GPIO_PIN_12
define MAX6675_CS_GPIO_Port GPIOB SPI_HandleTypeDef hspi2;/ USER CODE BEGIN Includes / / USER CODE END Includes / / Private typedef -----------------------------------------------------------// USER CODE BEGIN TD / / USER CODE END TD / / Private define ------------------------------------------------------------// USER CODE BEGIN Define / / USER CODE END Define / / Private macro -------------------------------------------------------------// USER CODE BEGIN Macro / / USER CODE END Macro / / Private variables ---------------------------------------------------------// USER CODE BEGIN PV / / USER CODE END PV / / Private function prototypes -----------------------------------------------// USER CODE BEGIN PFP / / USER CODE END PFP / / External functions --------------------------------------------------------// USER CODE BEGIN ExternalFunctions / / USER CODE END ExternalFunctions / / USER CODE BEGIN 0 //**
/ USER CODE END SPI2_Init 0 / / USER CODE BEGIN SPI2_Init 1 / / USER CODE END SPI2_Init 1 // SPI2 parameter configuration/hspi2.Instance = SPI2;hspi2.Init.Mode = SPI_MODE_MASTER;hspi2.Init.Direction = SPI_DIRECTION_2LINES;hspi2.Init.DataSize = SPI_DATASIZE_8BIT;hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;hspi2.Init.NSS = SPI_NSS_SOFT;hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;hspi2.Init.TIMode = SPI_TIMODE_DISABLE;hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;hspi2.Init.CRCPolynomial = 7;hspi2.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;hspi2.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;if (HAL_SPI_Init( hspi2) != HAL_OK){Error_Handler();}}/ USER CODE END 0 /void HAL_MspInit(void){/ USER CODE BEGIN MspInit 0 / / USER CODE END MspInit 0 / HAL_RCC_SYSCFG_CLK_ENABLE();HAL_RCC_PWR_CLK_ENABLE(); / System interrupt init/ / USER CODE BEGIN MspInit 1 / / USER CODE END MspInit 1 /} /**
/ USER CODE BEGIN 1 / //MAX6675 片选引脚初始化void GPIO_Init(void){GPIO_InitTypeDef GPIO_InitStruct = {0}; / GPIO Ports Clock Enable /__HAL_RCC_GPIOB_CLK_ENABLE(); HAL_GPIO_WritePin(GPIOB, MAX6675_CS_Pin, GPIO_PIN_SET);/引脚配置 /GPIO_InitStruct.Pin = MAX6675_CS_Pin;GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;GPIO_InitStruct.Pull = GPIO_NOPULL;GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;HAL_GPIO_Init(GPIOB, GPIO_InitStruct);} /**
2413 浏览 1 评论
3129 浏览 1 评论
1698 浏览 1 评论
3511 浏览 6 评论
5867 浏览 21 评论
857浏览 4评论
1232浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
501浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1214浏览 3评论
1269浏览 3评论
GMT+8, 2024-9-20 23:27 , Processed in 0.865149 second(s), Total 40, Slave 35 queries .
