代码功能是创建客户端,静态ip,在407跑通了,但是直接复制移植到429的板子就运行报错,用的ucosii,请问可能是啥原因,lwip初始化成功,tcp客户端也初始化成功,之后就运行调试串口打印出这个 那几行代码是 |
This assertion means that the q (queue) pointer in the ARP table entry is not NULL, which should not be the case when trying to find an empty entry in the ARP table. This could be caused by a memory allocation issue or a problem with the network interface driver.
One possibility is that the memory settings are different between the two boards, leading to a memory allocation error on the STM32F429 board. Another possibility is that the network interface driver code is not properly adapted to the new board and is causing the ARP table entry to be incorrectly initialized. I suggest checking the memory settings, making sure they match between the two boards, and reviewing the code for the network interface driver to ensure it is correctly configured for the STM32F429 board. It may also be helpful to debug the code and narrow down the specific line of code causing the error. |
零知开源——基于STM32F407VET6零知增强板的四路独立计时器
1215 浏览 0 评论
零知开源——STM32F4实现ILI9486显示屏UI界面系列教程(一):电子书阅读器功能
1518 浏览 0 评论
CW32L010 ESC Driver 电机控制套件快速上手指南
1176 浏览 1 评论
1900 浏览 1 评论
1977 浏览 0 评论
13642 浏览 31 评论
GMT+8, 2025-7-8 18:49 , Processed in 0.508034 second(s), Total 38, Slave 32 queries .
