各位大大安安,在官方BSP\tiMER_Capture范例中,提到Timer0和Timer3的输出频率各位500Hz和1Hz,但是实际上则是1000Hz和2Hz,这其中是不是有什么误会???,谢谢!
printf(" Timer0: Clock source is 12 MHz; Toggle-output mode and frequency is 500 Hz.\n"); printf(" Timer3: Clock source is 12 MHz; Toggle-output mode and frequency is 1 Hz.\n"); printf(" Timer2: Clock source is HCLK(72 MHz); Continuous counting mode; TCMP is 0xFFFFFF;\n"); printf(" Counter pin enable; Capture pin and capture interrupt enable;\n"); printf("# Generate 500 Hz frequency from TM0 and connect TM0 pin to Timer2 counter pin.\n"); printf("# Generate 1 Hz frequency from TM3 and connect TM3 pin to TM2_EXT capture pin.\n"); printf("# Get 500 event counts from Timer2 counter pin when each TM2_EXT pin interrupt occurred.\n\n"); /* Initial Timer0 and Timer3 default setting */ timer0_freq = TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000); timer3_freq = TIMER_Open(TIMER3, TIMER_TOGGLE_MODE, 2); printf("Timer0 frequency = %d\n",timer0_freq); printf("Timer3 frequency = %d\n",timer3_freq); |
可以有几种可能性导致实际的输出频率与手册中不一致:
1. BSP中的代码可能有错误 2. 手册中的描述可能有误 3. BSP和手册中描述的都是默认情况下的频率,但实际项目中可能有修改过的参数导致频率不同。 需要仔细查看代码和手册以确定原因。 |
442 浏览 0 评论
999 浏览 1 评论
2386 浏览 5 评论
2701 浏览 9 评论
2524 浏览 6 评论
560浏览 9评论
563浏览 7评论
669浏览 6评论
536浏览 5评论
577浏览 5评论
GMT+8, 2024-9-21 23:23 , Processed in 1.016034 second(s), Total 78, Slave 59 queries .
