// File Function: N76E003 APROM program DATAFLASH as EEPROM way //*********************************************************************************************************** #include "N76E003.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_define.h" #define ADDR_BASE 0x4700 #define FLASH_L_LOW ADDR_BASE+1 #define FLASH_L_HIGH ADDR_BASE+2 #define FLASH_H_LOW ADDR_BASE+3 #define FLASH_H_HIGH ADDR_BASE+4 volatile unsigned char xdata page_buffer[128]; UINT8 Read_APROM_BYTE(UINT16 code *u16_addr) { UINT8 rdata; rdata = *u16_addr>>8; return rdata; } *u16_addr>>8;为什么要右移的? |
The shift right by 8 bits (>>) is used to obtain the high byte of the data stored in the flash memory. In this specific code, it is used to read the data from the EEPROM (which is emulated using the flash memory of the N76E003 controller), since it is stored in a word (2-byte) format with the high byte stored first followed by the low byte. Therefore, shifting right by 8 bits will get the high byte of the data and shifting left by 8 bits will get the low byte of the data.
3363 浏览 0 评论
3370 浏览 9 评论
3061 浏览 16 评论
3551 浏览 1 评论
9182 浏览 16 评论
1304浏览 3评论
671浏览 2评论
663浏览 2评论
2411浏览 2评论
1978浏览 2评论
GMT+8, 2025-2-24 05:11 , Processed in 1.049426 second(s), Total 46, Slave 38 queries .
