// File Function: N76E003 Watch Dog reste functiondemo code //*********************************************************************************************************** #include "N76E003.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_define.h" /*********************************************************************** WDT CONFIG enable warning : this macro is only when ICP not enable CONFIG WDT function copy this marco code to you code to enable WDT reset. ************************************************************************/ void Enable_WDT_Reset_Config(void) { set_IAPEN; IAPAL = 0x04; IAPAH = 0x00; IAPFD = 0x0F; IAPCN = 0xE1; set_CFUEN; set_IAPGO; //trigger IAP while((CHPCON&SET_BIT6)==SET_BIT6); //check IAPFF (CHPCON.6) clr_CFUEN; clr_IAPEN; } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { Set_All_GPIO_Quasi_Mode; clr_GPIO1; Timer0_Delay1ms(50); //toggle I/O to show MCU Reset set_GPIO1; Timer0_Delay1ms(50); clr_GPIO1; Timer0_Delay1ms(50); set_GPIO1; Timer0_Delay1ms(50); //---------------------------------------------------------------------------------------------- // WDT Init !!! ENABLE CONFIG WDT FIRST !!! // Warning: // Always check CONFIG WDT enable first, CONFIG not enable, SFR can't enable WDT reset // Please call Enable_WDT_Reset_Config() function to enable CONFIG WDT reset //---------------------------------------------------------------------------------------------- // Enable_WDT_Reset_Config(); //刚开始烧录例程代码,没反应 后面打开这个才有了复位 TA=0xAA;TA=0x55;WDCON=0x07; //Setting WDT prescale set_WDCLR; //Clear WDT timer while((WDCON|~SET_BIT6)==0xFF); //confirm WDT clear is ok before into power down mode EA = 1; set_WDTR; //WDT run while(1) { clr_GPIO1; Timer0_Delay1ms(500); set_GPIO1; Timer0_Delay1ms(500); clr_GPIO1; Timer0_Delay1ms(500); set_GPIO1; Timer0_Delay1ms(500); set_PD; } } 当我想烧之前的代码(没有加看门狗的代码) 结果他一直进入复位 在论坛上说是对配置字进行了修改 但是在keil里也没找到可以如何修改看门狗使能的相关配置 |
void main (void) { clr_WDCON_WDTF; //清除看门狗复位标志 ENABLE_GLOBAL_INTERRUPT; //打开总中断 /* 看门狗初始化 */ MODIFY_HIRC(HIRC_24); //设置内部高速RC时钟频率为24MHz MODIFY_HCLK(HIRC,1); //设置系统时钟为内部高速RC时钟,时钟分频为1 MODIFY_HIRC(HIRC_12); //设置看门狗时钟频率为12MHz MODIFY_WDCON(WDCON_PRESET_Msk|WDCON_CLRDA_Msk|0x05); //设置看门狗预设值为0x05,清除看门狗时不清除芯片数据 ENABLE_WDT_INTERRUPT; //使能看门狗中断 set_WDCON_WDTR; //启动看门狗 while (1) { /* 编写主程序代码 */ } } void WDT_ISR(void) interrupt 10 { clr_WDCON_WDTF; //清除看门狗复位标志 set_WDCON_WDTR; //重新启动看门狗 /* 编写看门狗中断代码,保证每次看门狗中断时上面的主程序代码执行时间不会超过看门狗预设时间 */ } |
884 浏览 0 评论
1197 浏览 1 评论
2575 浏览 5 评论
2911 浏览 9 评论
2773 浏览 6 评论
1241浏览 3评论
222浏览 2评论
496浏览 2评论
403浏览 2评论
486浏览 1评论
GMT+8, 2025-2-1 16:57 , Processed in 0.986326 second(s), Total 45, Slave 37 queries .
