case 3:
if (MotorA.FlagBEMF == 0) //未检测到过零事件 MotorA.FlagBEMF 过零事件标志 { if (MotorA.PWMticks >= 4)//消磁 { if ( BEMF()) //判断是否过零点 { MotorA.FlagSwitchStep = MotorA.PWMTicksPre >> 4; //延迟30电角度 PWMTicksPre记录的是上一步的时间 MotorA.FlagBEMF = 1; //检测到过零事件,不再检测 } } } else { if (MotorA.FlagSwitchStep == 0) //延迟时刻到 { BLDC_SwitchStep(); //换向 BEMF_Cnt++; //换向计数加1 } else { MotorA.FlagSwitchStep--; //延时时刻未到,自减 } } if (BEMF_Cnt >= 800000) //800000次换向之后,停止 { MotorA.State++; //状态加1 BEMF_Cnt = 0; //换向计数清零 } break; case 4: BLDC_Stop(); break; |
The reason why the commutation happens more than 80000 times in three-step commutation of brushless DC motor for back electromotive force detection may depend on several factors, including:
1. The speed and load of the motor: Higher speeds and heavier loads may require more frequent commutation to maintain smooth operation and avoid torque ripple. 2. The accuracy of the back EMF detection circuit: The reliability and precision of the sensor or algorithm used to detect the zero-crossing of back EMF signals can affect the timing and frequency of commutation. 3. The design of the motor and driver: The number of motor poles and the driving algorithm (e.g. sinusoidal vs trapezoidal) can impact the commutation frequency, as well as the choice of PWM frequency and duty cycle. In the given code snippet, it seems that the commutation occurs when the back EMF zero-crossing is not detected for a certain period of time, and the motor is demagnetized if the PWM ticks exceed a threshold. However, without more context or information about the specific motor and circuit used, it is difficult to determine the exact reason for the high commutation frequency. |
3318 浏览 9 评论
2995 浏览 16 评论
3494 浏览 1 评论
9063 浏览 16 评论
4088 浏览 18 评论
1183浏览 3评论
609浏览 2评论
601浏览 2评论
2336浏览 2评论
1897浏览 2评论
GMT+8, 2024-12-25 01:20 , Processed in 1.237846 second(s), Total 81, Slave 62 queries .
