我正在尝试在 Cortex-A53 和 M7 之间的 IMX8MP 上使用 RPMsg 功能。更具体地说,现在我正在尝试将它与示例 imx_rpmsg_tty 驱动程序一起使用,以便在它们之间建立一个简单的字符设备接口。我已经阅读了一些我发现的文档,并使用示例设备树 `arch/arm64/boot/dts/freescale/imx8mp-evk-rpmsg.dts` 作为我的基础。但是我很难找到 RPMsg 节点本身的文档,我想问一个问题列表。也请原谅我,因为我对 BSP 开发还是个新手。
首先,这是我创建的设备树(它是示例 DTS 的修改/修剪版本,添加了 rpmsg 节点): #include #include /* * ATTENtiON: M7 may use IPs/peripherals including: * ECSPI0/ECSPI2, FLEXCAN, GPIO1/GPIO5, GPT1, I2C3, I2S3, UARTs, * PWM4, SDMA1/SDMA2, and more. Any peripheral used by the cortex M7 * must be disabled in the device tree and must be added to domain 1 * in the U-Boot device tree. */ / { // This is for RPMsg. Specifically, at least for the imx_rpmsg_tty driver rpmsg: rpmsg { compatible = "fsl,imx8mq-rpmsg"; reg = <0x0 0x55000000 0x0 0x80000>; memory-region = <&vdevbuffer>; vdev-nums = <1>; /* up to now, the following channels are used in imx rpmsg * - tx1/rx1: messages channel. * - general interrupt1: remote proc finish re-init rpmsg stack * when A core is partition reset. */ mbox-names = "tx", "rx", "rxdb"; mboxes = <μ 0 1 μ 1 1 μ 3 1>; status = "okay"; }; reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; // M7 TCM instruction memory // Linux/Cortex-A physically can't access this area of memory m7_itcm: m7@0x7E0000 { no-map; reg = <0 0x7E0000 0 0x20000>; }; // M7 TCM data memory // Linux/Cortex-A physically can't access this area of memory m7_dtcm: m7@0x800000 { no-map; reg = <0 0x800000 0 0x20000>; }; // M7 RAM // This is used if the Cortex-M is booted from RAM m7_reserved: m7@0x80000000 { no-map; reg = <0 0x80000000 0 0x1000000>; }; // IMX Remote Proc; tx buffer 32KiB vdev0vring0: vdev0vring0@55000000 { compatible = "shared-dma-pool"; reg = <0 0x55000000 0 0x8000>; no-map; }; // IMX Remote Proc; rx buffer 32KiB vdev0vring1: vdev0vring1@55008000 { compatible = "shared-dma-pool"; reg = <0 0x55008000 0 0x8000>; no-map; }; rsc_table: rsc-table@550ff000 { reg = <0 0x550ff000 0 0x1000>; no-map; }; /* RPMsg buffer; this is 64KiB which is 32KiB for the * TX and RX buffers each. The start address is defined * as the `VDEV0_VRING_BASE` define in the Cortex M7 code. */ vdevbuffer: vdevbuffer@55400000 { compatible = "shared-dma-pool"; reg = <0 0x55400000 0 0x100000>; no-map; }; }; // IMX remote proc imx8mp-cm7 { compatible = "fsl,imx8mp-cm7"; rsc-da = <0x55000000>; clocks = <&clk IMX8MP_CLK_M7_DIV>; fsl,startup-delay-ms = <500>; mbox-names = "tx", "rx", "rxdb"; mboxes = <μ 0 1 μ 1 1 μ 3 1>; memory-region = <&vdevbuffer>, <&vdev0vring0>, <&vdev0vring1>, <&rsc_table>; status = "okay"; }; }; 哦,还有一张纸条;我正在从 TCM 启动 Cortex-M7,并且没有使用远程 proc 来启动/停止/热加载它。另外,我的内核是 v5.15。 所以我对此的问题如下:
`vdevbuffer` 引用通常在使用 RPMsg 功能时需要,因为它是在远程处理器和本地主机之间传输消息的缓冲区。在 imx8mp-cm7 上使用 RPMsg 时,您需要确保已经将 vdevbuffer 引用添加到设备树中的 RPMsg 节点中。
在您的设备树中的 RPMsg 节点中,您需要指定 `reg` 属性,以及 `vdevbuffer` 和 `status` 属性。这些属性告诉内核在哪里可以找到 RPMsg 的缓冲区,并且应该如何对其进行操作。 下面是一个示例 RPMsg 节点的定义: ``` rpmsg { compatible = "linux,rpmsg-virtio"; status = "okay"; reg = <0x0000 0x0 0x0 0x0 0x0>; vdevbuffer = <&rpmsg_virtio0_buffer>; }; ``` 请注意,`reg` 属性设置为零,因为在这种情况下,RPMsg 缓冲区是使用内存映射 I/O 访问的,而不是使用设备寄存器。 `vdevbuffer` 属性设置为对缓冲区的引用,例如 `&rpmsg_virtio0_buffer`。 一旦您的设备树配置正确,您就可以在 imx_rpmsg_tty 示例驱动程序中使用 RPMsg 功能了。请记住,在使用 RPMsg 时,您需要在远程处理器和本地主机之间协调好消息格式和协议。例如,您需要确保在远程处理器和本地主机之间传输的消息具有相同的大小和格式,否则可能会出现不可预测的行为。 |
1951个成员聚集在这个小组
36511 浏览 0 评论
5824 浏览 1 评论
6181 浏览 1 评论
6880 浏览 0 评论
4292 浏览 0 评论
693浏览 2评论
671浏览 2评论
685浏览 2评论
766浏览 2评论
891浏览 2评论
GMT+8, 2025-1-25 03:55 , Processed in 0.952033 second(s), Total 43, Slave 38 queries .
