我正在使用 GUI Guider 1.5.1-GA。
在我的 PC (Windows 11) 中,我能够在 GUI Guider 中生成给定示例的代码。但是,在我们正在开发的项目中,我无法再生成代码了。 我得到了 Java 错误列表: Caused by: java.lang.OutOfMemoryError: Java heap space at java.util.Arrays.copyOf(Unknown Source) at java.lang.AbstractStringBuilder.ensureCapacityInternal(Unknown Source) at java.lang.AbstractStringBuilder.append(Unknown Source) at java.lang.StringBuffer.append(Unknown Source) at java.io.StringWriter.write(Unknown Source) at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:625) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:171) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:171) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:171) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.directive.Foreach.renderBlock(Foreach.java:309) at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:279) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:304) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.directive.Foreach.renderBlock(Foreach.java:309) at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:279) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:304) at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:439) at org.apache.velocity.runtime.directive.Parse.render(Parse.java:284) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:304) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:147) at org.apache.velocity.runtime.directive.Foreach.renderBlock(Foreach.java:309) at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:279) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:304) at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:439) at org.apache.velocity.Template.merge(Template.java:358) at org.apache.velocity.Template.merge(Template.java:262) at controller.Uit.main(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) 我只在我的电脑上遇到过这个问题。当我使用另一台装有 Windows 11 的 PC 和 h 相同的项目时,它运行良好。 当 GUI Guider 正确创建代码时和不正确创建代码时,我都附上了日志。 我注意到这两个日志非常不同。此外,当它不起作用时,它似乎可以正确生成 C 代码,但是当它切换到 MicroPython 代码时,它会循环相同的图像大约 30 次(而且它不应该不要这样做)! |
1932个成员聚集在这个小组
36421 浏览 0 评论
4867 浏览 1 评论
6108 浏览 1 评论
6818 浏览 0 评论
4249 浏览 0 评论
647浏览 2评论
643浏览 2评论
645浏览 2评论
729浏览 2评论
844浏览 2评论
GMT+8, 2024-12-23 22:37 , Processed in 1.116884 second(s), Total 76, Slave 60 queries .
