大家好:
我遇到了一个SPI设备驱动(Sitronix st7262)探测问题 在我们的硬件设计中,st7262(面板)通过 ecspi2 连接到 imx8mm 相关DTS &ecspi2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi2>; fsl,spi-num-chipselects = <1>; cs-gpios = <&gpio5 13 GPIO_ACtiVE_LOW>; dmas = <&sdma1 2 7 0>, <&sdma1 3 7 0>; dma-names = "rx", "tx"; status = "okay"; panel@0 { reg = <0>; display-id = "840000"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lcd_module>; compatible = "sitronix,st7262"; spi-max-frequency = <4000000>; spi-bits-per-word = <8>; spi-working-mode = <0>; spi-cs-gpios = <&gpio5 13 GPIO_ACTIVE_HIGH>; power-supply = <®_lcm_lcd_vdd>; enable-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>; backlight = <&backlight>; pre-enable; status = "okay";在驱动程序中(panel-sitronix-st7262.c) static int st7262_probe(struct spi_device *spi) { struct device *dev = &spi->dev; struct device_node *np = dev->of_node; struct st7262 *ctx; struct device_node *timings = NULL; int ret = 0; dev_err(&spi->dev, "start st7262 probe\n"); ctx = devm_kzalloc(&spi->dev, sizeof(*ctx), GFP_KERNEL); if (!ctx) return -ENOMEM; ...... 该驱动程序由 CONFIG_DRM_PANEL_SITRONIX_ST7262=m 使用 ko 构建 该驱动程序由 SharedBoardConfig.mk (i2c-imx.ko -->i2c-dev.ko -->spidev.ko ->spi-bitbang.ko ->spi-nxp-fspi.ko ->spi-imx .ko --> leds-lm3697.ko --> panel-sitronix-st7262.ko ...) 我 feq ($(IMX8MM_USES_GKI),true) BOARD_VENDOR_RAMDISK_KERNEL_MODULES += \ .... $(KERNEL_OUT)/drivers/gpu/drm/panel/panel-sitronix-st7262.ko \ ... 然而,当系统启动时,我可以看到 spi_imx 正在创建 spi0、spi1 总线,但我看不到驱动程序被探测(控制台应该打印“start st7262 probe”) 2.987023] spi_imx 30820000.spi: registered master spi0 [ 2.988160] spi spi0.0: spi_imx_setup: mode 0, 8 bpw, 4000000 hz [ 2.988170] spi spi0.0: setup mode 0, 8 bits/w, 4000000 Hz max --> 0 [ 2.988415] spi_imx 30820000.spi: registered child spi0.0 [ 2.989033] spi_imx 30830000.spi: registered master spi1 [ 2.989828] spi spi1.0: spi_imx_setup: mode 0, 8 bpw, 4000000 hz [ 2.989847] spi spi1.0: setup mode 0, 8 bits/w, 4000000 Hz max --> 0 [ 2.990357] spi_imx 30830000.spi: registered child spi1.0相同的文件和设置适用于我们之前的操作系统 (Android 12) 有人知道如何进一步调试吗? |
1963个成员聚集在这个小组
36571 浏览 0 评论
5974 浏览 1 评论
6244 浏览 1 评论
6937 浏览 0 评论
4325 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-23 16:21 , Processed in 1.101269 second(s), Total 74, Slave 58 queries .
