要将ESP8266连接到需要用户名/密码身份验证的telnet服务器,您需要使用适当的库和代码。下面是一些指导:
1. 在Arduino IDE中安装ESP8266库。 2. 使用ESP8266WiFi库连接到WiFi网络。您可以使用以下代码: ``` #include const char* ssid = "your-network-ssid"; const char* password = "your-network-password"; void setup() { Serial.begin(9600); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.println("Connecting to WiFi..."); } Serial.println("Connected to WiFi"); } void loop() { // Your code here } ``` 3. 使用WiFiClientSecure库连接到telnet服务器。您需要将服务器的IP地址和端口替换为您的服务器的详细信息,并设置用户名和密码。以下是代码示例: ``` #include #include const char* ssid = "your-network-ssid"; const char* password = "your-network-password"; const char* serverIp = "your-server-ip"; const int serverPort = 23; // telnet port WiFiClientSecure client; void setup() { Serial.begin(9600); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.println("Connecting to WiFi..."); } Serial.println("Connected to WiFi"); client.setInsecure(); // skip certificate verification } void loop() { if (!client.connected()) { Serial.println("Connecting to server..."); if (client.connect(serverIp, serverPort)) { Serial.println("Connected to server"); if (client.find("login:")) { Serial.println("Sending username..."); client.println("your-username"); delay(1000); if (client.find("password:")) { Serial.println("Sending password..."); client.println("your-password"); delay(1000); if (client.find(">")) { Serial.println("Logged in successfully"); // Your code here } } } } else { Serial.println("Connection failed"); } } } ``` 注意:这只是一个简单的例子,并且可能需要根据您的需求进行修改。 4. 设置WiFi热点和Web服务器来创建热点用户。您可以使用ESP8266WebServer库来设置Web服务器,并使用ESP8266WiFi库来创建WiFi热点。以下是代码示例: ``` #include #include const char* ssid = "your-network-ssid"; const char* password = "your-network-password"; ESP8266WebServer server(80); void setup() { Serial.begin(9600); WiFi.softAP("your-hotspot-ssid", "your-hotspot-password"); delay(1000); IPAddress ip = WiFi.softAPIP(); Serial.print("Access Point IP address: "); Serial.println(ip); server.on("/", [](){ server.send(200, "text/html", " Welcome to hotspot portal");}); server.on("/login", [](){ String username = server.arg("username"); String password = server.arg("password"); if (username == "admin" && password == "admin") { server.send(200, "text/html", " Welcome, admin");} else { server.send(200, "text/html", " Invalid username or passwordBack");} }); server.begin(); } void loop() { server.handleClient(); } ``` 注意:此代码仅用于演示目的,并且可能需要根据您的需求进行修改。请务必考虑安全问题,例如使用HTTPS来保护用户身份验证数据。 |
262个成员聚集在这个小组
加入小组695 浏览 1 评论
3470 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
663浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
370浏览 3评论
1476浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
1733浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
398浏览 2评论
GMT+8, 2025-8-11 00:13 , Processed in 0.612916 second(s), Total 73, Slave 57 queries .
