我得到了 IP,可以从笔记本电脑上 ping 通它。我已经结束将波特率切换回 115200。
我的目标是远程连接到 Arduino 以从 OTA 编程/读取数据。我已经 。 为此,我尝试按照此处的示例在 ESP8266 模块上设置 ESP 。我已经按照 安装了额外的板,但是当我上传代码时,我不断收到有关数据包标头的错误。 代码:全选Executable segment sizes: ICACHE : 32768 - flash instruction cache IROM : 248724 - code in flash (default or ICACHE_FLASH_ATTR) IRAM : 26797 / 32768 - code in IRAM (IRAM_ATTR, ISRs...) DATA : 1504 ) - initialized variables (global, static) in RAM/HEAP RODATA : 1052 ) / 81920 - constants (global, static) in RAM/HEAP BSS : 25712 ) - zeroed variables (global, static) in RAM/HEAP Sketch uses 278077 bytes (26%) of program storage space. Maximum is 1044464 bytes. Global variables use 28268 bytes (34%) of dynamic memory, leaving 53652 bytes for local variables. Maximum is 81920 bytes. esptool.py v3.0 Serial port /dev/ttyACM0 Connecting........_____....._____....._____....._____....._____....._____....._____ Traceback (most recent call last): File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/upload.py", line 66, in esptool.main(cmdline) File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 3552, in main esp.connect(args.before, args.connect_attempts) File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 529, in connect raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error)) esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook with os.fdopen(os.open(pr_filename, FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_bin_python3.8.1000.crash' Original exception was: Traceback (most recent call last): File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/upload.py", line 66, in esptool.main(cmdline) File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 3552, in main esp.connect(args.before, args.connect_attempts) File "/home/aprenewables/.arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool/esptool.py", line 529, in connect raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error)) esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header |
这种错误通常是由于通讯波特率的问题引起的。请确保您使用的是与ESP8266模块相同的波特率。您还可以尝试将ESP8266模块重置为默认设置,并使用默认波特率进行通信(9600或74880)。另外,请确保您正在使用正确的串行端口。如果问题仍然存在,请检查您的代码和连接以确保它们正确无误。
184个成员聚集在这个小组
加入小组461 浏览 1 评论
1545 浏览 2 评论
629浏览 6评论
523浏览 5评论
500浏览 5评论
504浏览 4评论
493浏览 4评论
GMT+8, 2025-2-13 23:27 , Processed in 0.765212 second(s), Total 77, Slave 61 queries .
