以下是 LPCXpresso55S16 中 ADC 的配置步骤和示例代码,需要使用 Zephyr 3.3.99:
1. 在 Zephyr 的 Kconfig 文件中启用 ADC 配置,可以使用以下命令: ```bash west build -b lpcxpresso55s16 samples/boards/lpcxpresso55s69/ ``` 2. 在应用程序中包含头文件 "drivers/adc.h",并使用以下函数初始化 ADC 控制器: ```c struct adc_seq_table table = { .channels = BIT(0), // Using channel 0 .buffer = &readings[0], .buffer_size = sizeof(readings), .resolution = 12, .options = 0, }; adc_sequence_setup(dev, &table); ``` 3. 使用以下函数启动 ADC 转换,并等待读取结果: ```c adc_read(dev, &table); // Wait for the conversion to complete while (adc_is_busy(dev)) { k_busy_wait(1); } // Process the readings for (int i = 0; i < table.buffer_size; i++) { LOG_INF("ADC reading %d: %d", i, readings[i]); } ``` 完整示例代码: ```c #include #include #include #include LOG_MODULE_REGISTER(app); void main(void) { int readings[4] = {0}; const struct device *dev = device_get_binding(DT_LABEL(DT_NODELABEL(adc0))); if (!dev) { LOG_ERR("Failed to get ADC device"); return; } struct adc_seq_table table = { .channels = BIT(0), // Using channel 0 .buffer = &readings[0], .buffer_size = sizeof(readings), .resolution = 12, .options = 0, }; if (adc_sequence_setup(dev, &table) != 0) { LOG_ERR("Failed to setup ADC sequence"); return; } while (1) { adc_read(dev, &table); // Wait for the conversion to complete while (adc_is_busy(dev)) { k_busy_wait(1); } // Process the readings for (int i = 0; i < table.buffer_size; i++) { LOG_INF("ADC reading %d: %d", i, readings[i]); } k_sleep(K_SECONDS(1)); } } ``` |
1976个成员聚集在这个小组
36600 浏览 0 评论
6052 浏览 1 评论
6269 浏览 1 评论
6957 浏览 0 评论
4333 浏览 0 评论
744浏览 2评论
723浏览 2评论
734浏览 2评论
811浏览 2评论
930浏览 2评论
GMT+8, 2025-3-8 13:56 , Processed in 1.025029 second(s), Total 46, Slave 40 queries .
