我已经将 max31855 与 arduino 一起使用了一段时间,我认为是时候将项目迁移到 esp 平台了。我没有找到适用于 Wemos D1 的任何 max31855 防护罩,所以我的计划是自己制作一个。但是,当将模块直接连接到 wemos 时,我无法使用 adafruit 的示例代码 serialtermocouple 获得任何信号:
代码:全选/*************************************************** This is an example for the Adafruit Thermocouple Sensor w/MAX31855K Designed specifically to work with the Adafruit Thermocouple Sensor These displays use SPI to communicate, 3 pins are required to interface Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit! Written by Limor Fried/Ladyada for Adafruit Industries. BSD license, all text above must be included in any redistribution ****************************************************/ #include #include "Adafruit_MAX31855.h" // Default connection is using software SPI, but comment and uncomment one of // the two examples below to switch between software SPI and hardware SPI: // Example creating a thermocouple instance with software SPI on any three // digital IO pins. //arduino nano //#define MAXDO 4 //#define MAXCS 5 //#define MAXCLK 3 // esp8266 #define MAXDO D6//12 #define MAXCS D1//5 #define MAXCLK D5//14 // initialize the Thermocouple Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO); // Example creating a thermocouple instance with hardware SPI (Uno/Mega only) // on a given CS pin. //#define MAXCS 10 //Adafruit_MAX31855 thermocouple(MAXCS); #if defined(ARDUINO_ARCH_SAMD) // for Zero, output on USB Serial console, remove line below if using programming port to program the Zero! #define Serial SerialUSB #endif void setup() { #ifndef ESP8266 while (!Serial); // will pause Zero, Leonardo, etc until serial console opens #endif Serial.begin(9600); Serial.println("MAX31855 test"); // wait for MAX chip to stabilize delay(500); } void loop() { // basic readout test, just print the current temp Serial.print("Internal Temp = "); Serial.println(thermocouple.readInternal()); double c = thermocouple.readCelsius(); if (isnan(c)) { Serial.println("Something wrong with thermocouple!"); } else { Serial.print("C = "); Serial.println(c); } //Serial.print("F = "); //Serial.println(thermocouple.readFarenheit()); delay(1000); } 我搭建了一个只有max31855、一个arduino和一个wemos d1的面包板来对比定位问题。 我的设置照片: arduino nano(左)通过逻辑电平转换器连接,因为它在 5V 上运行,而 max31855 需要 3.3V。esp 直接连接到模块。有点难看,但所有颜色都根据以下颜色编码: 5V 红色 3.3V 橙色 gnd 黑色 DO 蓝色 CS 紫色 CLK 黄色 它在 arduino 上工作得很好,但从 esp 我只得到零读数: 我已经为 wemos 测试了一些不同的引脚,但似乎没有任何区别。 根据我的阅读,将 esp 与 max 芯片一起使用应该没有问题。 |
首先,请确保你在正确的引脚连接上 max31855 模块。你需要确保 SCK、CS 和 DO 引脚都正确连接。
如果连接正确,可以尝试增加一些延迟时间。有时候,ESP8266 需要更多的时间来与 max31855 进行通信。你可以在代码中进行尝试更改以下行: #define MAX31855_DELAY_MS 1000 将其更改为较长的延迟时间。 另外,请确保代码中引用的 SPI 库与你的 Wemos D1 兼容。有时,需要使用不同的 SPI 库。你可以尝试更改以下行: #include 将其更改为以下内容: #include #include 如果这些方法都不能解决问题,可能需要考虑其他问题,例如你的硬件是否损坏,或者是否有错误的代码。 |
125个成员聚集在这个小组
加入小组457浏览 6评论
385浏览 5评论
365浏览 5评论
371浏览 4评论
344浏览 4评论
GMT+8, 2024-9-20 15:26 , Processed in 0.660400 second(s), Total 44, Slave 39 queries .
