请注意,我使用的是Python语言进行编写:
import socket def send_request(host, port, path): """ Send a GET request to a server with the specified host, port, and path. Returns the response from the server. """ # Create a socket and connect to the server s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) s.connect((host, port)) # Send the GET request to the server request = "GET {} HTTP/1.1rnHost: {}rnrn".format(path, host) s.send(request.encode()) # Receive the response from the server response = "" while True: data = s.recv(1024) if not data: break response += data.decode() # Close the connection to the server s.close() return response # Send a request to Server 1 response1 = send_request("server1.com", 80, "/path/to/resource") # Send a request to Server 2 response2 = send_request("server2.com", 80, "/path/to/other/resource") |
166个成员聚集在这个小组
加入小组1149 浏览 1 评论
582浏览 6评论
480浏览 5评论
465浏览 5评论
466浏览 4评论
441浏览 4评论
GMT+8, 2024-12-24 00:07 , Processed in 0.723849 second(s), Total 47, Slave 41 queries .
