我正在尝试从 UART 读取数据并通过 TCP 连接将它们发送到服务器,但变量中存储的数据为空?但是当打印这个变量时它不是空的。
如何解决这个问题? 代码:全选uart.setup( 0, 57600, 8, 0, 1, 0 ) uart.on("data", "{", function(raw) raw1 = raw1 .. raw if string.find(raw1, "}") then print("Recived: " .. raw1 .. "END") local raw2 = 'fffff' .. tostring(raw1) --test to see if something is sended, to server is sended only 'fffff' print("Sending to RPi") Send(raw2) uart.on("data") end end, 0) function Send(data) print("Sending to RPi") conn=net.createConnection(net.TCP, 0) conn:on("receive", function(conn, payload) print(payload) end) conn:connect(80,"192.168.1.12") conn:send("GET /piec/dane.php?json="..data.." HTTP/1.1\r\n") conn:send("Host: 192.168.1.12\r\n") conn:send("Connection: keep-alive\r\nAccept: */*\r\n") conn:send("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n") conn:send("\r\n") conn:on("sent",function(conn) print("Closing connection") conn:close() end) conn:on("disconnection", function(conn) print("Got disconnection...") print(node.heap()) end) end |
179个成员聚集在这个小组
加入小组438 浏览 1 评论
1376 浏览 1 评论
606浏览 6评论
505浏览 5评论
486浏览 5评论
487浏览 4评论
470浏览 4评论
GMT+8, 2025-1-21 19:19 , Processed in 0.898526 second(s), Total 73, Slave 57 queries .
