我正在尝试将数字麦克风连接到我的 i.mx 8m mini evk 上的 SAI5 扩展引脚。这是我的设备树:
codec_dummy: codec_dummy { compatible = \"asoc,snd-soc-dummy\"; #sound-dai-cells = <0>; pinctrl-names = \"default\"; pinctrl-0 = <&pinctrl_gpio_wlf>; frame-master; bitclock-master; status = \"okay\"; }; sound-sai5 { compatible = \"simple-audio-card\"; simple-audio-card,name=\"sound | sai5\"; simple-audio-card,format=\"i2s\"; simple-audio-card,frame-master=<&sai5>; simple-audio-card,bitclock-master=<&sai5>; status=\"okay\"; cpu_dai:simple-audio-card,cpu{ sound-dai=<&sai5>; system-clock-frequency=<&clk IMX8MM_CLK_SAI5_ROOT>; }; codec_dai: simple-audio-card,codec{ sound-dai=<&codec_dummy>; system-clock-frequency=<&clk IMX8MM_CLK_SAI5_ROOT>; }; }; &sai5 { compatible=\"fsl,imx8mm-sai\"; pinctrl-names = \"default\"; pinctrl-0 = <&pinctrl_sai5>; assigned-clocks=<&clk IMX8MM_CLK_SAI5>; assigned-clocks-parents=<&clk IMX8MM_AUDIO_PLL1_OUT>; assigned-clock-rates = <4096000>; fsl,sai-mclk-direction-output; fsl,txmasterflag = <0>; fsl,mode=\"i2s-master\"; status=\"okay\"; }; 当我运行 arecord -l 命令时,我可以看到界面,当我运行 pactrl list 时,在无限循环中打印出以下错误: fsl-sai 30050000.sai: ASoC: error at snd_soc_dai_hw_params on 30050000.sai: -22 [ 1875.936608] 30050000.sai-snd-soc-dummy-dai: ASoC: soc_pcm_hw_params() failed (-22) [ 1875.944756] fsl-sai 30050000.sai: failed to derive required Rx rate: 1411200 |
2009个成员聚集在这个小组
36697 浏览 0 评论
6187 浏览 1 评论
6409 浏览 1 评论
7030 浏览 0 评论
4432 浏览 0 评论
888浏览 2评论
1001浏览 2评论
1160浏览 2评论
如何读取MPC5777C单片机中的pwm信号?有没有应用示例或代码示例?
504浏览 2评论
1603浏览 2评论
GMT+8, 2025-4-24 17:01 , Processed in 0.599635 second(s), Total 75, Slave 59 queries .
