BK7238 Datasheet_V1.2.pdf
(792.57 KB, 下载次数: 7
BK7238 是一款高度集成 Wi-Fi 802.11bgn 和 BLE 的双模低功耗芯片,通过两个两个 DC/DC 降压电流。DtiM10 功耗低可达 150uA;我司是上海博通一级代理商;郑 158-8977-4125 BK7238芯片核心参数如下: Core and Memory •32-bit MCU at up to 160 MHz •SiP Flash options: 1 MB, 2 MB or none (depending on package) •288 KB RAM •4-byte eFuse •UART/JTAG for download and debug Wi-Fi •IEEE 802.11 b/g/n 1x1 compliant •Supports 20 MHz channel •STBC supported •Working mode STA, AP, Direct •Concurrent AP + STA •TX power up to +19 dBm •RX sensitivity -99 dBm Power Management •2.7 to 3.6 V VBAT supplyFeatures •On-chip power-on reset (POR) and brown-out detector (BOD) •Embedded LDO regulators •Low power consumption: -Active mode RX: 30 mA -Normal standby mode: 300 μA -Low voltage standby mode: 75 μA -Shutdown mode: 0.5 μ BK7238可应用于智能家居产品上,可支持低功耗长连接,大大减少用电量;也可应用于IPC等视频流的传输。 |
GMT+8, 2024-9-23 07:26 , Processed in 0.432903 second(s), Total 68, Slave 49 queries .
