我正在尝试将 HTTPS 发布到 Microsoft Flow。
我可以像这样使用 apister.com 发布到 Flow;我试图用 ESP8266 复制这个但有问题。我找到了以下示例 - https://github.com/esp8266/Arduino/issues/2834这是我的代码 代码:全选#include //https://github.com/esp8266/Arduino #include #include #include #include //https://github.com/tzapu/WiFiManager #include void setup() { Serial.begin(115200); Serial.println(\"Attempting to connect to wifi\"); WiFiManager wifiManager; //wifiManager.resetSettings(); //reset saved settings wifiManager.autoConnect(\"AutoConnectAP\"); Serial.println(\"connected\"); } void loop() { Serial.println(\"attempt POST\"); HTTPClient http; http.begin(\"https://prod-23.westeurope.logic.azure.com:443/workflows/4221219928b1479186337912abba9907/triggers/manual/paths/invoke?api-version=2016-06-01&sp=%2Ftriggers%2Fmanual%2Frun&sv=1.0&sig=FxDTZGTHI1iF784ILXLXM707U0TonG_j_xxxxxxxxxxx\"); http.addHeader(\"Content-Type\", \"application/json\"); String postMessage = \"{\'temp\':\'21\'}\"; int httpCode = http.POST(postMessage); Serial.print(\"http result:\"); Serial.println(httpCode); http.writeToStream(&Serial); String payload = http.getString(); http.end(); delay(5000); //Post Data at every 5 seconds } 我唯一的输出是; 代码:全选Attempting to connect to wifi *WM: *WM: AutoConnect *WM: Connecting as wifi client... *WM: Using last saved values, should be faster *WM: Connection result: *WM: 3 *WM: IP Address: *WM: 192.168.43.166 connected *WM: freeing allocated params! attempt POST http result:-1 |
119个成员聚集在这个小组
加入小组423浏览 6评论
357浏览 5评论
336浏览 5评论
339浏览 4评论
319浏览 4评论
GMT+8, 2024-8-28 22:49 , Processed in 0.705964 second(s), Total 73, Slave 57 queries .
