我正在尝试从 Wunderground 获取信息以显示在我正在建设的气象站上
我可以使用 openweathermap.org 使其正常工作但我无法让 Wunderground 工作 任何人都可以提供帮助吗? 代码:全选timesetup(1) print time() delay 1000 print time() timer 10 * 1000, [RUNPROGRAM] wait [RUNPROGRAM] cls PRINT \"TIME\" & \",\" & time() serialprintln \"TIME\" & \",\" & time() let query = \"api.openweathermap.org/data/2.5/weather?q=Denton,uk〈=en&units=metric&appid=API_KEY_HERE\" delay 500 let ret = wget(query) let temp = json(ret,\"main.temp\") let press = json(ret,\"main.pressure\") let humid = json(ret,\"main.humidity\") let speed = json(ret,\"main.speed\") speed1 = int(main.speed + 0.5) let dir = json(ret,\"main.deg\") let icon = json(ret,\"main.icon\") let desc = json(ret,\"description\") println \"Today,\" & desc & \",\" & icon & \",\" & temp & \",\" & press &\",\" & speed1 & \",\" & dir & \",\" & humid 代码:全选timesetup(1) print time() delay 1000 print time() timer 10 * 1000, [RUNPROGRAM] wait [RUNPROGRAM] cls PRINT \"TIME\" & \",\" & time() \'println \"TIME\" & \",\" & time() let query = \"api.wunderground.com/api/API_KEY_HERE/conditions/q/UK/Audenshaw.json\" delay 10 let ret = wget(query) let temp = json(ret,\"temp_c\") let press = json(ret,\"pressure_mb\") let humid = json(ret,\"relative_humidity\") let speed = json(ret,\"main.speed\") speed1 = int(wind_mph) let dir = json(ret,\"wind_degrees\") let icon = json(ret,\"icon\") let desc = json(ret,\"wind_string\") println \"Today,\" & desc & \",\" & icon & \",\" & temp & \",\" & press &\",\" & speed1 & \",\" & dir & \",\" & humid |
171个成员聚集在这个小组
加入小组350 浏览 0 评论
1196 浏览 1 评论
588浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
445浏览 4评论
GMT+8, 2024-12-29 15:41 , Processed in 0.778436 second(s), Total 75, Slave 59 queries .
