我正在尝试使用 DeleteAll() 但无法使其正常工作。我正在使用 NXPPlugNTrust nano-package API。我正在采取的步骤:
写入用户 ID(相关部分): uint8_t userId[] = DELETE_ALL_USERID_VALUE; status = Se05x_API_WriteUserID( &session, &policy, 0, kSE05x_AppletResID_FACTORY_RESET, userId, sizeof(userId), kSE05x_AttestationType_AUTH ); 使用全部删除: smStatus_t status; Se05xSession_t session = { 0 }; size_t sessionIdLen = sizeof(se05x_applet_session_value); set_keys( &session, scp03_key_enc, sizeof(scp03_key_enc), scp03_key_mac, sizeof(scp03_key_mac) ); status = Se05x_API_SessionOpen(&session); if (status != SM_OK) { SMLOG_E(\"Se05x_API_SessionOpen %x\\n\", status); return status; } uint8_t userId[] = DELETE_ALL_USERID_VALUE; SE05x_Result_t exists = kSE05x_Result_FAILURE; size_t sessionIdLen = sizeof(se05x_applet_session_value); status = Se05x_API_CheckObjectExists( &session, kSE05x_AppletResID_FACTORY_RESET, &exists ); if (status != SM_OK) { SMLOG_E(\"Se05x_API_CheckObjectExists %x\\n\", status); return status; } status = Se05x_API_CreateSession( &session, kSE05x_AppletResID_FACTORY_RESET, &se05x_applet_session_value[0], &sessionIdLen ); if (status != SM_OK) { SMLOG_E(\"Se05x_API_CreateSession %x\\n\", status); return status; } status = Se05x_API_VerifySessionUserID(&session, userId, sizeof(userId)); if (status != SM_OK) { SMLOG_E(\"Se05x_API_VerifySessionUserID %x\\n\", status); return status; } status = Se05x_API_DeleteAll(&session); if (status != SM_OK) { SMLOG_E(\"Se05x_API_DeleteAll: %x\", status); return status; } return status; 我附上了一个调试控制台输出,其中包括设置用户 ID 和使用它。 |
1963个成员聚集在这个小组
36571 浏览 0 评论
5974 浏览 1 评论
6244 浏览 1 评论
6937 浏览 0 评论
4325 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-24 05:00 , Processed in 1.064843 second(s), Total 75, Slave 59 queries .
