扫一扫,分享给好友
我无法让 flex-builder 干净地完成。
我在 Ubuntu 20.04 LTS 上,并确保我已安装此文档第 2 页所需的所有软件包: 我必须安装的尚未安装的软件包是:socat、python3-git、python3-jinja2、libegl1-mesa、libsdl1.2-dev、pylint3、xterm、python3-subunit、mesa-common-dev、zstd、和 liblz4 工具。 我已从此处的链接重新下载并重新安装: https: //lsdk.github.io/components.html 以下是命令: $ flex-builder -i 清洁固件 $ flex-builder -c atf -m lx2160ardb_rev2 -b xspi 它摆脱了: make[2]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf \' /rcw/lx2160ardb_rev2/XGGFF_PP_HHHH_RR_19_5_2/rcw_2200_750_3200_19_5_2.bin BL33=/home/ajedgar/Git/flexbuild_lsdk2108_github/build/firmware/u-boot/lx2160ardb/uboot_lx2160ardb_ tfa.bin BL32=/home/ajedgar/Git/flexbuild_lsdk2108_github/components/apps/security /optee_os/out/arm-plat-ls/core/tee_lx2160ardb.bin SPD=opteed make[2]: 进入目录\'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf\' 包括服务/spd/opteed/opteed .mk 设置chsis make[2]: *** 没有制定目标 \'plat/nxp/soc-lx2160a/LX2160A_RDB/ddr_init.c\' 的规则,\'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf/build/lx2160ardb 需要/release/bl2/ddr_init.o\'。停止。 make[2]: *** 等待未完成的工作.... 构建工具/fiptool/fiptool HOSTCC tbbr_config.c HOSTCC fiptool.c HOSTLD fiptool 成功构建fiptool make[2]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf\' cp: cannot stat \'build/lx2160ardb/release/bl2_flexspi_nor*.pbl\': No such file or directory atf.mk:11 : 目标 \'atf\' 的配方失败 make[1]: *** [atf] 错误 1 make[1]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/packages/firmware\' Makefile:19: 目标配方 \' atf\' failed make: *** [atf] Error 2 make: Leaving directory \'/home/ajedgar/Git/flexbuild_lsdk2108_github\' 如果我尝试下一步: $ flex-builder -i mkfw -m lx2160ardb_rev2 -b xspi 它以非常相似的方式摆脱困境: make[2]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf \' /rcw/lx2160ardb_rev2/XGGFF_PP_HHHH_RR_19_5_2/rcw_2200_750_3200_19_5_2.bin BL33=/home/ajedgar/Git/flexbuild_lsdk2108_github/build/firmware/u-boot/lx2160ardb/uboot_lx2160ardb_ tfa.bin BL32=/home/ajedgar/Git/flexbuild_lsdk2108_github/components/apps/security /optee_os/out/arm-plat-ls/core/tee_lx2160ardb.bin SPD=opteed make[2]: 进入目录\'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf\' 包括服务/spd/opteed/opteed .mk 设置chsis make[2]: *** 没有制定目标 \'plat/nxp/soc-lx2160a/LX2160A_RDB/ddr_init.c\' 的规则,\'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf/build/lx2160ardb 需要/release/bl2/ddr_init.o\'。停止。 make[2]: *** 等待未完成的工作.... 构建工具/fiptool/fiptool HOSTCC fiptool.c HOSTCC tbbr_config.c HOSTLD fiptool 成功构建fiptool make[2]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/components/firmware/atf\' cp: cannot stat \'build/lx2160ardb/release/bl2_flexspi_nor*.pbl\': No such file or directory atf.mk:11 : 目标 \'atf\' 的配方失败 make[1]: *** [atf] 错误 1 make[1]: 离开目录 \'/home/ajedgar/Git/flexbuild_lsdk2108_github/packages/firmware\' Makefile:19: 目标配方 \' atf\' failed make: *** [atf] Error 2 make: Leaving directory \'/home/ajedgar/Git/flexbuild_lsdk2108_github\' |
1951个成员聚集在这个小组
36517 浏览 0 评论
5852 浏览 1 评论
6188 浏览 1 评论
6889 浏览 0 评论
4296 浏览 0 评论
703浏览 2评论
677浏览 2评论
691浏览 2评论
770浏览 2评论
898浏览 2评论
GMT+8, 2025-1-31 07:35 , Processed in 0.756062 second(s), Total 42, Slave 37 queries .
