使用 NodeMCU-PyFlasher.exe 和 flash_download_tool_3.9.2.exe 烧录均成功,但是AT没反应。
下面是 NodeMCU-PyFlasher.exe 的日志 Command: esptool.py --port COM3 --baud 115200 --after no_reset write_flash --flash_size detect --flash_mode dio 0x00000 E:\AWS\aithinker\ESP8266-IDF-AT_V2.2.1.0\ESP8266-AT-V2.2.1.0\factory\factory_WROOM-02.bin --erase-all esptool.py v3.0 Serial port COM3 Connecting.... Detecting chip type... ESP8266 Chip is ESP8266EX Features: WiFi Crystal is 26MHz MAC: 40:f5:20:2c:62:7b Uploading stub... Running stub... Stub running... Configuring flash size... Auto-detected Flash size: 4MB Erasing flash (this may take a while)... Chip erase completed successfully in 8.9s Flash params set to 0x024f Compressed 2097152 bytes to 546983... Wrote 2097152 bytes (546983 compressed) at 0x00000000 in 48.8 seconds (effective 343.8 kbit/s)... Hash of data verified. Leaving... Staying in bootloader. Firmware successfully flashed. Unplug/replug or reset device to switch back to normal boot mode. 换烧录阿里云这个固件AT正常: NodeMcu-AT-1\Ai-Thinker_ESP8266_DOUT_AiCloud_v0.0.0.6_20170517\firmware\Ai-Thinker_ESP8266_DOUT_32Mbit_AiCloud_0.0.0.6_20170517.bin |
127个成员聚集在这个小组
加入小组457浏览 6评论
385浏览 5评论
366浏览 5评论
371浏览 4评论
344浏览 4评论
GMT+8, 2024-9-20 23:23 , Processed in 0.603901 second(s), Total 42, Slave 36 queries .
