本文转载自:https://bbs.aw-ol.com/topic/3281/
由于UART0 被设定为系统dubug 输出(简单来说就是将ttyS0 设定为console),所以使用UART3 作为普通的串口,进行与别的设备通信。
1. 查看硬件电路图SCH_Schematic1_2022-11-23,查看uart3 的TX RX pin 脚
电路图pdf路径:Yuzukilizard/Hardware/Schematic/SCH_Schematic1_2022-11-23.pdf
从图中可以看出TX = PE12 RX = PE13 。
PE12 PE13 可以通过排插用杜邦线接出,排插电路图如下:
2. 由于pin脚复用原因,我们需要查看pin 脚复用情况
pin 脚复用手册V851SE_PINOUT_V0.1.xlsx路径:
Yuzukilizard/Hardware/Datasheets/V851SE_PINOUT_V0.1.xlsx
记住PE12 PE13 用作UART3-TX UART3-RX 是function7 ,这个很重要,一会我们在board.dts 文件中需要用到。
3. 配置设备树文件 board.dts
设备树文件通过of 文件解析出属性,进一步被应用(原理此处不再介绍)。
board.dts 路径:tina-v853-docker/device/config/chips/v851s/configs/lizard/board.dts
在设备树中搜索UART 找到UART3 相关配置
&uart0 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&uart0_pins_active>;
pinctrl-1 = <&uart0_pins_sleep>;
status = "okay";
&uart1 {
pinctrl-0 = <&uart1_pins_active>;
pinctrl-1 = <&uart1_pins_sleep>;
status = "disabled";
&uart2 {
pinctrl-0 = <&uart2_pins_active>;
pinctrl-1 = <&uart2_pins_sleep>;
&uart3 {
pinctrl-0 = <&uart3_pins_active>;
pinctrl-1 = <&uart3_pins_sleep>;
status = "okay";
&pio {
uart0_pins_active: uart0@0 {
allwinner,pins = "PH9", "PH10";
allwinner,function = "uart0";
allwinner,muxsel = <5>;
allwinner,drive = <1>;
allwinner,pull = <1>;
uart0_pins_sleep: uart0@1 {
allwinner,function = "gpio_in";
allwinner,muxsel = <0>;
uart1_pins_active: uart1@0 {
allwinner,pins = "PG6", "PG7";
allwinner,function = "uart1";
allwinner,muxsel = <4>;
uart1_pins_sleep: uart1@1 {
uart2_pins_active: uart2@0 {
allwinner,pins = "PA8", "PA9";
allwinner,function = "uart2";
allwinner,muxsel = <6>;
uart2_pins_sleep: uart2@1 {
uart3_pins_active: uart3@0 {
allwinner,pins = "PE12", "PE13";
allwinner,function = "uart3";
allwinner,muxsel = <7>;
uart3_pins_sleep: uart3@1 {
1)将uart3 设定为 status = "okay";
2)将uart3 pin 脚设为 allwinner,pins = "PE12", "PE13";
3)将uart3 pin复用为function7 :allwinner,muxsel = <7>;
修改完成后,重新编译img
make -j1 V=s
pack
使用烧录软件:PhoenixSuit ,具体烧录方法参考:https://dongshanpi.com/YuzukiHD-Lizard/03-1_FlashSystem/#usb
烧录后,通过adb shell 进入终端,就可以查看到设备节点:/dev/ttyS3 ,通过open 设备终端,就可以进行read write 操作。
4. 通过设备节点 /dev/ttyS3 进行收发操作
1)写应用程序
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <termios.h>
#include <errno.h>
#include <string.h>
enum parameter_type {
PT_PROGRAM_NAME = 0,
PT_DEV_NAME,
PT_CYCLE,
PT_NUM
#define DBG(string, args...) \
do { \
printf("%s, %s()%u---",__FILE__,__FUNCTION__,__LINE__); \
printf(string, ##args); \
printf("\n"); \
} while (0)
void usage(void) {
printf("You should input as: \n");
printf("\t select_test [/dev/name] [Cyclee Cnt]\n");
int OpenDev(char *name) {
int fd = open(name, O_RDWR );
if (-1 == fd)
DBG("Can not OPen(%s)!", name);
return fd;
void set_speed(int fd, int speed) {
int i;
int status;
struct termios Opt = {0};
int speed_arr[] = {B230400, B115200, B57600, B38400, B19200, B9600, B4800, B2400, B1200, B300, B38400, B19200, B9600, B4800, B2400, B1200, B300, };
int name_arr[] = {230400,115200, 57600, 38400, 19200, 9600, 4800, 2400, 1200, 300, 38400, 19200, 9600, 4800, 2400, 1200, 300, };
tcgetattr(fd, &Opt);
for ( i= 0; i < sizeof(speed_arr) / sizeof(int); i++) {
if (speed == name_arr[i])
break;
tcflush(fd, TCIOFLUSH);
cfsetispeed(&Opt, speed_arr[i]);
cfsetospeed(&Opt, speed_arr[i]);
Opt.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
Opt.c_oflag &= ~OPOST;
status = tcsetattr(fd, TCSANOW, &Opt);
if (status != 0) {
DBG("tcsetattr fd");
return;
int set_Parity(int fd,int databits,int stopbits,int parity) {
struct termios options;
if ( tcgetattr( fd,&options) != 0) {
perror("SetupSerial 1");
return -1;
options.c_cflag &= ~CSIZE;
switch (databits)
case 7:
options.c_cflag |= CS7;
break;
case 8:
options.c_cflag |= CS8;
break;
default:
fprintf(stderr,"Unsupported data size\n");
return -1;
switch (parity)
case 'n':
case 'N':
options.c_cflag &= ~PARENB;
options.c_iflag &= ~INPCK;
break;
case 'o':
case 'O':
options.c_cflag |= (PARODD | PARENB);
options.c_iflag |= INPCK;
break;
case 'e':
case 'E':
options.c_cflag |= PARENB;
options.c_cflag &= ~PARODD;
break;
case 'S':
case 's':
options.c_cflag &= ~CSTOPB;break;
default:
fprintf(stderr,"Unsupported parity\n");
return -1;
switch (stopbits)
case 1:
break;
case 2:
options.c_cflag |= CSTOPB;
break;
default:
fprintf(stderr,"Unsupported stop bits\n");
return -1;
if (parity != 'n')
tcflush(fd,TCIFLUSH);
options.c_cc[VTIME] = 150;
options.c_cc[VMIN] = 0;
if (tcsetattr(fd,TCSANOW,&options) != 0) {
perror("SetupSerial 3");
return -1;
return 0;
void str_print(char *buf, int len) {
int i;
for (i=0; i<len; i++) {
if (i%10 == 0)
printf("\n");
printf("0x%02x ", buf[i]);
printf("\n");
int main(int argc, char **argv)
int i = 0;
int fd = 0;
int cnt = 0;
char buf[256];
char buf_s[4];
int ret;
fd_set rd_fdset;
struct timeval dly_tm;
if (argc != PT_NUM) {
usage();
return -1;
sscanf(argv[PT_CYCLE], "%d", &cnt);
if (cnt == 0)
cnt = 0xFFFF;
fd = OpenDev(argv[PT_DEV_NAME]);
if (fd < 0)
return -1;
set_speed(fd,19200);
if (set_Parity(fd,8,1,'N') == -1) {
printf("Set Parity Error\n");
exit (0);
printf("Select(%s), Cnt %d. \n", argv[PT_DEV_NAME], cnt);
while (i<cnt) {
FD_ZERO(&rd_fdset);
FD_SET(fd, &rd_fdset);
dly_tm.tv_sec = 5;
dly_tm.tv_usec = 0;
memset(buf, 0, 256);
ret = select(fd+1, &rd_fdset, NULL, NULL, &dly_tm);
DBG("select() return %d, fd = %d", ret, fd);
if (ret == 0)
continue;
if (ret < 0) {
printf("select(%s) return %d. [%d]: %s \n", argv[PT_DEV_NAME], ret, errno,
strerror(errno));
continue;
i++;
ret = read(fd, buf, 256);
printf("Cnt%d: read(%s) return %d.\n", i, argv[PT_DEV_NAME], ret);
str_print(buf, ret);
buf_s[0] = 0x55;
buf_s[1] = 0xAA;
buf_s[2] = 0x55;
buf_s[3] = 0xAA;
write(fd, buf_s, 256);
DBG("send over %d\n");
close(fd);
return 0;
2) 编写makefile
CROSS_COMPILE=/home/xxx/v851s/Yuzukilizard/toolchain/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-
AS = $(CROSS_COMPILE)as
LD = $(CROSS_COMPILE)ld
CC = $(CROSS_COMPILE)gcc
CXX = $(CROSS_COMPILE)g++
CPP = $(CC) -E
AR = $(CROSS_COMPILE)ar
NM = $(CROSS_COMPILE)nm
STRIP = $(CROSS_COMPILE)strip
OBJCOPY = $(CROSS_COMPILE)objcopy
OBJDUMP = $(CROSS_COMPILE)objdump
RANLIB = $(CROSS_COMPILE)ranlib
SIZE = $(CROSS_COMPILE)size
TOP_DIR = $(shell pwd)
CFLAGS_inc_path += -I$(TOP_DIR)
EXE = UARTTest
SRC_HAL += ./
LIB_SRC := $(foreach spath, $(SRC_HAL), $(wildcard $(spath)*.c))
OBJECT += $(patsubst %.c,%.o,$(LIB_SRC))
LOCAL_INCLUDE += -I./
CFLAGS += $(LOCAL_INCLUDE) -static
all:$(EXE)
$(EXE):$(OBJECT)
@$(CC) $(OBJECT) -o $(EXE) $(CFLAGS)
@echo "Compile target done."
@echo "use src files"
$(OBJECT):
.PHONY:clean
clean:
@rm -rf *.o $(OBJECT) $(EXE)
@echo "Clean done."
需注意,将makefile 中的编译工具路径修改为自己的工具路径。
3) make 后,产生可执行文件,adb push 到开发板中进行执行,执行命令:
./UARTTest /dev/ttyS3 4
4)用杜邦线将PE12 PE13 GND 三根线接到电脑串口(需要串口转换小板子),波特率目前设定19200 ,使用串口工具,向板子随便发送数据,板子接受到数据,就会发送数据到电脑。
