使用Android Automotive 12.0.0_2.1.0 (Linux 5.15.32 BSP) 在 i.MX8QXP 内部 PLL 上看不到 pcie
mek_8q:/ # zcat /proc/config.gz | grep -i imx_pci CONFIG_PHY_FSL_IMX_PCIE=y mek_8q:/ # zcat /proc/config.gz | grep -i pci_imx CONFIG_PCI_IMX6=y CONFIG_PCI_IMX6_HOST=y mek_8q:/ # dmesg | grep -i pci [ 0.000000] Kernel command line: stack_depot_disable=on kasan.stacktrace=off kvm-arm.mode=protected cgroup_disable=pressure console=ttyLP0,115200 earlycon init=/init androidboot.hardware=nxp firmware_class.pe [ 0.314189] PCI: CLS 0 bytes, default 64 [ 2.834329] tcpci: probe of 1-0050 failed with error -1 mek_8q:/ # lspci mek_8q:/ # HW 应该没问题,因为我们可以在 uboot 中看到它(请忽略 gpio 错误,为了快速测试我们还没有设置它。) => pci pca953x gpio@1a: Error reading output register imx_pcie pcie@0x5f010000: -16 unable to get clkreq. imx_pcie pcie@0x5f010000: -2 unable to get disable-gpio. pca953x gpio@1a: Error reading output register imx_pcie pcie@0x5f010000: 3 unable to get power-on-gpio. imx_pcie pcie@0x5f010000: -16 unable to get power-on-gpio. PCI: pcie phy link never came up 我们也可以通过这个 dts 配置在 linux 上看到它 &pcieb{ ext_osc = <0>; }; |
1934个成员聚集在这个小组
36427 浏览 0 评论
4963 浏览 1 评论
6114 浏览 1 评论
6821 浏览 0 评论
4250 浏览 0 评论
653浏览 2评论
646浏览 2评论
647浏览 2评论
736浏览 2评论
848浏览 2评论
GMT+8, 2024-12-26 16:03 , Processed in 1.294255 second(s), Total 46, Slave 40 queries .
