试图在我的基于 imx8mm 的板上添加一个键盘。
我将其添加到我的设备树中: [...] gpio-keys { compatible = "gpio-keys"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpio_keys>; col0_btn { label = "COL0_BTN"; gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; gpio-key,wakeup; linux,code = ; }; }; [...] &iomuxc { pinctrl_gpio_keys: keys0grp { fsl,pins = < MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x1d6 /* KEY_C0 */ >; }; [...] 在 Linux 中使用“gpioinfo”命令进行检查: root@asdf:~# gpioinfo 0 gpiochip0 - 32 lines: line 0: unnamed unused input active-high line 1: unnamed unused input active-high line 2: unnamed unused input active-high line 3: unnamed "interrupt" input active-high [used] line 4: unnamed unused input active-high line 5: unnamed "COL0_BTN" input active-low [used] 看起来不错。 检查 evtest /dev/input/event0 root@asdf:/# evtest /dev/input/event0 Input driver version is 1.0.1 Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100 Input device name: "gpio-keys" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 256 (BTN_0) Properties: Testing ... (interrupt to exit) 但是,从未注册过按钮的按下。我想知道之间是否以某种方式映射 gpios = <&gpio1 5 GPIO_ACTIVE_LOW> 和 MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 不正确,是不是看起来很明显? |
1963个成员聚集在这个小组
36571 浏览 0 评论
5974 浏览 1 评论
6244 浏览 1 评论
6937 浏览 0 评论
4325 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-23 15:21 , Processed in 1.056077 second(s), Total 75, Slave 59 queries .
