我的定制板将两个 10G phy(Marvell AQR113C 和 Broadcom BCM89890)连接到 serdes 并连接。mdc/mdio 到 EMI2-MDC/MDIO(引脚 AH3/AH4)。
RCW serdes 配置为 1133 和 5577。 在 uboot 中,我禁用了所有 1G 接口并启动了 10G 接口。 但是当进入u-boot控制台并执行mdio read时,示波器在MDIO引脚上没有信号。 附上日志和eth.c。请帮助找到解决方法。 谢谢。 U-Boot 2019.10-tegra-dirty (Apr 20 2023 - 11:18:19 +0800) SoC: LS1046AE Rev1.0 (0x87070010) Clock Configuration: CPU0(A72):1800 MHz CPU1(A72):1800 MHz CPU2(A72):1800 MHz CPU3(A72):1800 MHz Bus: 600 MHz DDR: 2100 MT/s FMAN: 700 MHz Reset Configuration Word (RCW): 00000000: 0c150012 0e000000 00000000 00000000 00000010: 11335577 40004002 60040000 c1000000 00000020: 00000000 00000000 00000000 00238800 00000030: 20124000 00003101 00000096 00000001 Model: LS1046A RDB Board Board: LS1046ARDB, boot from Invalid setting of SW5 CPLD: V0.0 PCBA: V0.0 SERDES Reference Clocks: SD1_CLK1 = 100.00MHZ, SD1_CLK2 = 100.00MHZ DRAM: 7.9 GiB (DDR4, 64-bit, CL=15, ECC on) SEC0: RNG instantiated Using SERDES1 Protocol: 4403 (0x1133) Using SERDES2 Protocol: 21879 (0x5577) NAND: 512 MiB MMC: FSL_SDHC: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment EEPROM: Read failed. In: serial Out: serial Err: serial Net: FM1_10GEC1 --------8 FM1_10GEC1_PHY_ADDR --------0 MMC read: dev # 0, block # 18432, count 128 ... Fman1: Uploading microcode version 106.4.18 PHY reset timed out PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: no link PCIe2: pcie@3600000 Root Complex: no link FM1@TGEC1 Warning: FM1@TGEC1 (eth0) using random MAC address - e6:e7:76:78:74:19 , FM1@TGEC2 Warning: FM1@TGEC2 (eth1) using random MAC address - 7a:d9:06:1c:52:8f Hit any key to stop autoboot: 0 => => mdio list FSL_MDIO0: FM_TGEC_MDIO: 0 - Generic 10G PHY <--> FM1@TGEC1 => mdio read FM1@TGEC1 0 Reading from bus FM_TGEC_MDIO PHY at address 0: 0 - 0xffff |
1951个成员聚集在这个小组
36520 浏览 0 评论
5860 浏览 1 评论
6196 浏览 1 评论
6898 浏览 0 评论
4302 浏览 0 评论
708浏览 2评论
682浏览 2评论
698浏览 2评论
776浏览 2评论
906浏览 2评论
GMT+8, 2025-2-2 11:39 , Processed in 1.250823 second(s), Total 42, Slave 36 queries .
