我在引脚初始化配置中将 PTC2 设置为 CAN RX 模式。
我可以在运行时将 PTC2 更改为 EIRQ[2] 吗? 无需更改引脚初始化配置。 而且,在运行时回到 CAN RX 模式? 谢谢 const Siul2_Port_Ip_PinSettingsConfig g_pin_mux_InitConfigArr0[NUM_OF_CONFIGURED_PINS0] = { { .base = IP_SIUL2, .pinPortIdx = 66u, .mux = PORT_MUX_AS_GPIO, .safeMode = PORT_SAFE_MODE_DISABLED, .inputFilter = PORT_INPUT_FILTER_DISABLED, .driveStrength = PORT_DRIVE_STRENTGTH_DISABLED, .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED, .slewRateCtrlSel = PORT_SLEW_RATE_SLOWEST, .pullKeep = PORT_PULL_KEEP_DISABLED, .invert = PORT_INVERT_DISABLED, .inputBuffer = PORT_INPUT_BUFFER_ENABLED, .outputBuffer = PORT_OUTPUT_BUFFER_DISABLED, .adcInterleaves = { MUX_MODE_NOT_AVAILABLE, MUX_MODE_NOT_AVAILABLE }, .inputMuxReg = { 0u }, .inputMux = { PORT_INPUT_MUX_ALT1, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT }, }, }; |
1965个成员聚集在这个小组
36573 浏览 0 评论
5979 浏览 1 评论
6247 浏览 1 评论
6939 浏览 0 评论
4326 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-25 00:31 , Processed in 0.935782 second(s), Total 46, Slave 40 queries .
