当我在 ubuntu20.04 上使用 flex builder 编译 tsntool 时,发现无法访问“的错误我读了另一篇文章那个来源。 codeaurora.org 停止服务了,那么现在有什么办法可以编译 tsntool 吗?
hingw@ubuntu:~/ls1028/flexbuild_lsdk2108$ flex-builder -c tsntool COMPONENT: tsntool make: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108' make[1]: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps' Building tsntool ... Cloning into '/home/hingw/ls1028/flexbuild_lsdk2108/components/apps/networking/tsntool'... fatal: unable to accessCould not resolve host: source.codeaurora.org make[1]: *** [/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps/networking/tsntool.mk:11: tsntool] Error 128 make[1]: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps' make: *** [Makefile:25: tsntool] Error 2 make: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108' 另外,我在github上看到tsntool源码包,编译器说明指定了一个kernal源码路径,这个路径应该填什么? 1. Libraries requirement Libraries libnl-3.0, libtermcap, libreadline libcjson are needed. 2. How to compile the tsntool: 2.1 Setup cross compile environment 2.2 Compile binary: > source source_arm64.sh > make The tsntool and libtsn.so will be generated. |
1866个成员聚集在这个小组
36188 浏览 0 评论
4285 浏览 0 评论
5915 浏览 1 评论
6658 浏览 0 评论
4109 浏览 0 评论
534浏览 2评论
525浏览 2评论
518浏览 2评论
599浏览 2评论
650浏览 2评论
GMT+8, 2024-9-21 03:23 , Processed in 0.683369 second(s), Total 42, Slave 37 queries .
