最近接触到S32K平台。使用 CAN_PAL 外围设备的环回测试失败。已经好几天了。请大家给个建议。代码很简单,如下:
CAN_PAL PIN_MUX #include "Cpu.h" #include "callbacks.h" #define TX_MAILBOX (1UL) #define TX_MSG_ID (1UL) #define RX_MAILBOX (0UL) #define RX_MSG_ID (1UL) volatile int exit_code = 0; can_message_t recvMsg; void BoardInit(void) { CLOCK_SYS_Init(g_clockManConfigsArr, CLOCK_MANAGER_CONFIG_CNT,g_clockManCallbacksArr, CLOCK_MANAGER_CALLBACK_CNT); CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_FORCIBLE); PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr); } void CAN1_Init(void) { CAN_Init(&can_pal1_instance, &can_pal1_Config0); can_buff_config_t RX_buffCfg = { .enableFD = false, .enableBRS = false, .fdPadding = 0U, .idType = CAN_MSG_ID_STD, .isRemote = false }; /* Configure RX buffer with index RX_MAILBOX */ CAN_ConfigRxBuff(&can_pal1_instance, RX_MAILBOX, &RX_buffCfg, RX_MSG_ID); can_buff_config_t TX_buffCfg = { .enableFD = false, .enableBRS = false, .fdPadding = 0U, .idType = CAN_MSG_ID_STD, .isRemote = false }; /* Configure RX buffer with index RX_MAILBOX */ CAN_ConfigTxBuff(&can_pal1_instance, TX_MAILBOX, &TX_buffCfg); ); } /* * @brief Function which configures the LEDs and Buttons */ int main(void) { BoardInit(); CAN1_Init(); can_message_t sendMsg = { .cs=0U, .id = RX_MSG_ID, .data[0] = 0x05, .length = 1U }; while(1) { CAN_Send(&can_pal1_instance,TX_MAILBOX,&sendMsg); while(CAN_GetTransferStatus(&can_pal1_instance, TX_MAILBOX) == STATUS_BUSY); CAN_Receive(&can_pal1_instance,RX_MAILBOX,&recvMsg); while(CAN_GetTransferStatus(&can_pal1_instance, RX_MAILBOX) == STATUS_BUSY); } |
1936个成员聚集在这个小组
36433 浏览 0 评论
5051 浏览 1 评论
6118 浏览 1 评论
6822 浏览 0 评论
4255 浏览 0 评论
655浏览 2评论
646浏览 2评论
647浏览 2评论
738浏览 2评论
853浏览 2评论
GMT+8, 2024-12-30 02:36 , Processed in 0.951957 second(s), Total 45, Slave 39 queries .
