我的电路板使用 50MHz 的外部时钟运行。MCG 和 OSC 在引导加载程序中设置,代码如下(来自 Keil Uvision 启动文件):
#elif (CLOCK_SETUP == 2) /* SIM_CLKDIV1: OUTDIV1=0,OUTDIV2=0,OUTDIV3=1,OUTDIV4=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */ SIM->CLKDIV1 = (uint32_t)0x00110000u; /* Update system prescalers */ /* Switch to FBE Mode */ /* OSC->CR: ERCLKEN=0,??=0,EREFSTEN=0,??=0,SC2P=0,SC4P=0,SC8P=0,SC16P=0 */ OSC->CR = (uint8_t)0x00u; /* MCG->C7: OSCSEL=0 */ MCG->C7 = (uint8_t)0x00u; /* MCG->C2: ??=0,??=0,RANGE0=2,HGO=0,EREFS=1,LP=0,IRCS=0 */ MCG->C2 = (uint8_t)0x24u; /* MCG->C1: CLKS=2,FRDIV=5,IREFS=0,IRCLKEN=0,IREFSTEN=0 */ MCG->C1 = (uint8_t)0xA8u; /* MCG->C4: DMX32=0,DRST_DRS=0 */ MCG->C4 &= (uint8_t)~(uint8_t)0xE0u; /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV0=0 */ MCG->C5 = (uint8_t)0x00u; /* MCG->C6: LOLIE=0,PLLS=0,CME=0,VDIV0=0 */ MCG->C6 = (uint8_t)0x00u; while((MCG->S & MCG_S_OSCINIT0_MASK) == 0u) { /* Check that the oscillator is running */ } while((MCG->S & MCG_S_IREFST_MASK) != 0u) { /* Check that the source of the FLL reference clock is the external reference clock. */ } while((MCG->S & 0x0Cu) != 0x08u) { /* Wait until external reference clock is selected as MCG output */ } /* Switch to BLPE Mode */ /* MCG->C2: ??=0,??=0,RANGE0=2,HGO=0,EREFS=1,LP=0,IRCS=0 */ MCG->C2 = (uint8_t)0x24u; #endif 我需要在主代码中禁用振荡器,以便我可以将 XTAL 引脚用作 GPIO。我试图通过设置 MCG_C2 的 EREFS 位来做到这一点,如以下代码所示,但之后偶尔会出现总线故障。 MCG->C2 &= ~MCG_C2_EREFS0_MASK; //set for external clock while((MCG->S & MCG_S_OSCINIT0_MASK ) != 0x00u); /* Wait until external reference clock is selected as MCG output */ 我是否需要执行其他顺序来执行此操作或等待其他状态? |
1866个成员聚集在这个小组
36194 浏览 0 评论
4292 浏览 0 评论
5922 浏览 1 评论
6666 浏览 0 评论
4114 浏览 0 评论
540浏览 2评论
533浏览 2评论
524浏览 2评论
605浏览 2评论
657浏览 2评论
GMT+8, 2024-9-22 21:31 , Processed in 1.008194 second(s), Total 76, Slave 60 queries .
