我正在尝试将 ADV7280-M 与我们的 IMX8X 板集成,但到目前为止我们还没有成功。
我在这里粘贴设备树定义和我们在 Linux 上得到的东西。 基本上,有2个问题: mxc-mipi-csi2.0: is_entity_link_setup, 未找到远程 pad! 和 mxc-mipi-csi2.0: mipi_csi2_enum_framesizes,未找到远程键盘! 不确定第二个是否是第一个的副作用。 我们有一个 CVBS 摄像头连接到 ADV7280-M 的 AIN1。 我看过其他关于 is_entity_link_setup 的帖子,但没有一个对我有帮助。任何人都可以检查我的配置并建议我应该如何在这里进行吗? 附上原理图的一部分。 &i2c1 { /* other stuff on this bus... */ adv7280m: adv7280m@21 { compatible = "adi,adv7280-m"; reg = <0x21>; status = "okay"; virtual-channel; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_cvbs_int>; powerdown-gpios = <&gpioexp0 6 GPIO_ACTIVE_LOW>; reset-gpios = <&gpioexp0 5 GPIO_ACTIVE_LOW>; interrupts = <4 IRQ_TYPE_EDGE_FALLING>; interrupt-parent = <&lsio_gpio3>; interrupt-names = "adv7280m_intrq"; port { adv7280_ep: endpoint { remote-endpoint = <&mipi_csi0_ep>; }; }; }; }; &mipi_csi_0 { status = "okay"; virtual-channel; csi = <0>; #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; mipi_csi0_ep: endpoint { remote-endpoint = <&adv7280_ep>; data-lanes = <1>; }; }; }; img_subsys: bus@58000000 { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges = <0x58000000 0x0 0x58000000 0x1000000>; /* other stuff... */ cameradev: camera { compatible = "fsl,mxc-md", "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges; /* other stuff... */ mipi_csi_0: csi@58227000 { compatible = "fsl,mxc-mipi-csi2"; reg = <0x58227000 0x1000>, <0x58221000 0x1000>; clocks = <&csi0_core_lpcg 0>, <&csi0_esc_lpcg 0>, <&csi0_pxl_lpcg 0>; clock-names = "clk_core", "clk_esc", "clk_pxl"; assigned-clocks = <&csi0_core_lpcg 0>, <&csi0_esc_lpcg 0>; assigned-clock-rates = <360000000>, <72000000>; power-domains = <&pd IMX_SC_R_CSI_0>, <&pd IMX_SC_R_ISI_CH0>; power-domain-names = "pd_csi", "pd_isi_ch0"; status = "disabled"; }; }; }; NXP i.MX Release Distro 5.15-kirkstone imx8qxp ttyLP0 root@imx8qxp-d7:~# uname -a Linux imx8qxp 5.15.71+g9b8ac3af0403 #1 SMP PREEMPT Mon Apr 3 13:43:17 UTC 2023 aarch64 GNU/Linux 根@imx8qxp-d7:~#dmesg | grep -e adv -e csi -e isi [1.720669] mxc-isi 58100000.isi:mxc_isi.0 注册成功 [1.733934] mxc-isi 58110000.isi:mxc_isi.1 注册成功 [1.741600] mxc-isi 58120000.isi: mxc_isi.2 注册成功 [1.749188] mxc-isi 58130000.isi:mxc_isi.3 注册成功 [2.122965] i2c 1-0021:修复循环依赖与 58227000.csi [2.686016] adv7180 1-0021:芯片 ID 0x231 找到 @ (5a810000.i2c) [ 2.918402] mxc-mipi-csi2 58227000.csi: 车道: 1, 名称: mxc-mipi-csi2.0 [ 3.259051] isi-m2m 58100000.isi:m2m_device: 为 ISI.0 [注册 m2m 成功7.445837] mx8-img-md:将 mxc_isi.0.capture 注册为 /dev/video3 [ 7.468924] mx8-img-md:将 mxc_isi.1.capture 注册为/dev/video4 [ 7.481234] mx8-img-md:将 mxc_isi.2.capture 注册为/dev/video5 [ 7.491578] mx8-img-md: 已注册mxc_isi.3.capture as /dev/video6 [7.502608] mx8-img-md:注册传感器子设备:adv7180 1-0021 (1) [7.502631] mx8-img-md:创建链接[mxc_isi.0] => [mxc_isi .0.capture] [ 7.502643] mx8-img-md: 创建链接 [mxc-mipi-csi2.0] => [mxc_isi.0] [ 7.502650] mx8-img-md: 创建链接 [mxc_isi.1] => [mxc_isi.1.capture] [ 7.502657] mx8-img-md: 创建链接 [mxc-mipi-csi2.0] => [mxc_isi.1] [ 7.502665] mx8-img-md: 创建链接 [mxc_isi.2] => [mxc_isi.2.capture] [7.502671] mx8-img-md: 创建链接 [mxc-mipi-csi2.0] => [mxc_isi.2] [7.502679]mx8-img-md:创建链接[mxc_isi.3]=>[mxc_isi.3.capture] [7.502686]mx8-img-md:创建链接[mxc-mipi-csi2.0]=>[mxc_isi。 3] [8.661369] mxc-mipi-csi2.0: is_entity_link_setup, 没有找到远程 pad! [8.672359]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! [8.679262]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! [8.741962]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! root@imx8qxp-d7:~# v4l2-ctl -d /dev/video3 --list-formats-ext [ 228.856447] mxc-mipi-csi2.0: is_entity_link_setup, 未找到远程板! ioctl: VIDIOC_ENUM_FMT[ 228.863708] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 没有找到远程键盘! 类型:视频捕获多平面 [0]: 'RGBP' (16-bit RGB 5-[ 228.872617] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, No remote pad found! 6-5) [1]: 'RGB3' (24-bit RGB 8- 8-8) [228.885291] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 没有找到远程键盘! [2]:'BGR3'(24 位 BGR 8-8-8) [228.895736] mxc-mipi-csi2.0:mipi_csi2_enum_framesizes,未找到远程板! [3]: 'YUYV' (YUYV 4:2:2) [ 228.905630] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 未找到远程键盘! [4]: 'YUV4' (32-bit A/XYUV 8-8-8-8) [ 228.915036] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 没有找到远程 pad! [5]: 'NV12' (Y/CbCr 4:2:0) [ 228.925473] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 未找到远程板! [6]: 'NM12' [ 228.934963] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 找不到远程键盘! [7]: 'YM24' (Planar YUV 4:4:4 (NC)) [ 228.945041] mxc-mipi-csi2.0: mipi_csi2_enum_framesizes, 未找到远程 pad! [8]:“XR24”(32 位 BGRX 8-8-8-8) [228.955466] mxc-mipi-csi2.0:mipi_csi2_enum_framesizes,未找到远程板! [9]: 'AR24'(32 位 BGRA 8-8-8-8) root@imx8qxp-d7:~# v4l2-ctl --list-devices [252.749448] mxc-mipi-csi2.0: is_entity_link_setup, 未找到远程板! [252.756157]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! [252.762850]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! [252.769574]mxc-mipi-csi2.0:is_entity_link_setup,找不到远程垫! amphion vpu 解码器(平台:amphion-vpu): /dev/video0 /dev/video1 /dev/media0 mxc-isi-cap(平台:58100000.isi:cap_devic): /dev/video3 mxc-isi-m2m(平台:58100000.isi:m2m_devic): /dev/video2 mxc-isi-cap(平台:58130000.isi:cap_devic): /dev/video6 mxc-jpeg 编解码器(平台:58400000.jpegdec): /dev/video7 mxc-jpeg 编解码器(平台:58450000.jpegenc): /dev/video8 mxc-isi-cap(平台:58130000.isi:cap_devic): /dev/video6 mxc-jpeg 编解码器(平台:58400000.jpegdec): /dev/video7 mxc-jpeg 编解码器(平台:58450000.jpegenc): /dev/video8 |
1935个成员聚集在这个小组
36428 浏览 0 评论
4971 浏览 1 评论
6114 浏览 1 评论
6821 浏览 0 评论
4252 浏览 0 评论
653浏览 2评论
646浏览 2评论
647浏览 2评论
737浏览 2评论
848浏览 2评论
GMT+8, 2024-12-27 00:33 , Processed in 1.230097 second(s), Total 76, Slave 60 queries .
